- Nov 3, 2003
- 47,941
The driveshaft (pic #2) is pretty straightforward. So we're good there.
The pinion shaft however (pic #1) is harder to dial in with the way you did it. You can still get pretty close by eyeballing your angle finder square to the centerline, but I think an angle/square thingy (carpenter's square?) would be ideal. With a small square you can lay it on the flat surface of the yoke (at the u-joint end) which would be 90 degrees to the angle you want to measure, but laying your angle-finder on the opposite beam of the square would get you into the same plane as the driveshaft.
If your current figures are correct, you are 14.3° off from parallel. You want 1-2 degrees, so you'd have to correct the pinion angle about 12-13 degrees up. Meaning you'd need about a 9 or 10 degree axle shim I think.
I never have memorized the geometry calculations needed to figure out what a change at the spring perch nets you at the pinion, but others here have figured it out.
I'm going to go read Steve's texts again to see if I'm missing something too. I've found some of the Ford writings to be unclear about what they're trying to help you achieve, but in theory everything we need to know is buried in his pages. I just need to figure out how to interpret them.
But see if you have a carpenter's square laying around somewhere you can use on that pinion to verify your existing measurements.
