Points to Electronic Ignition question
Lonestar
Austin, TX
I am replacing my points ignition with a Durispark 2 electronic ignition. The I have a duel advanced on the points distributor and single on the electronic. <br><br>- 1st is a duel advanced correct for a 73 302 auto?<br>- 2nd if the distributor came out of a later model 302 (the gear was replaced, with a brass gear, for a newer cam. Do I need to change it back or will it work with mine<br>- 3rd anything else I need to know? advise<br><br>Thanks<br>
mark74ranger
Albuquerque N.M.
By dual advance I'm assuming you are talking about the dual vacuum lines going to the vacuum advance. Actually the line closest to the body of the distributor is a vacuum retard line. When I went to the duraspark I bought a rebuilt motorcraft distributor from NAPA and had it calibrated at a local shop. The guy that did the calibration cut off the retard line so I wouldn't use it. He said it was for some purpose I can't remember now, probably emmissions, but that it adversly affected performance.<br><br>The brass gear should work fine for either a flat tappet iron cam or a steel roller cam.<br><br>Make sure you install a ballast resistor in series with the coil power wire.<br><br>Carry a spare duraspark box. They are $17 from Autozone with a lifetime warranty. If it dies, your bronco is dead, cheap insurance. I've had two die in the last 6 or 7 years.<br><br>Enjoy the Duraspark, it's the best $100 I've spent on the Bronco.
74bronc
[quote author=mark74ranger link=board=5;threadid=9206;start=0#65763 date=1032290729]<br>By dual advance I'm assuming you are talking about the dual vacuum lines going to the vacuum advance. Actually the line closest to the body of the distributor is a vacuum retard line. When I went to the duraspark I bought a rebuilt motorcraft distributor from NAPA and had it calibrated at a local shop. The guy that did the calibration cut off the retard line so I wouldn't use it. He said it was for some purpose I can't remember now, probably emmissions, but that it adversly affected performance.<br><br>The brass gear should work fine for either a flat tappet iron cam or a steel roller cam.<br><br>Make sure you install a ballast resistor in series with the coil power wire.<br><br>Carry a spare duraspark box. They are $17 from Autozone with a lifetime warranty. If it dies, your bronco is dead, cheap insurance. I've had two die in the last 6 or 7 years.<br><br>Enjoy the Duraspark, it's the best $100 I've spent on the Bronco.<br>[/quote]<br><br>Mark,<br><br>I am just curious, why a ballast resistor? I was told NOT to put a ballast resistor in mine when I converted over to Duraspark 3 years ago and my Bronco has been running fantastic ever since (knock on wood). If I remember right, part of the wire that goes to the coil is a resistance wire that drops the voltage down before it gets to the coil and in my understanding, this is the same thing a ballast resistor does.
mark74ranger
Albuquerque N.M.
Yes the wire that has the braided covering and connects to the hot side of the coil is the ballast resistor, that's what I have as well. It is a resistive wire. You can use either one the resistive wire or a discrete component. Same function, different style.
74bronc
[quote author=mark74ranger link=board=5;threadid=9206;start=0#65780 date=1032293979]<br>Yes the wire that has the braided covering and connects to the hot side of the coil is the ballast resistor, that's what I have as well. It is a resistive wire. You can use either one the resistive wire or a discrete component. Same function, different style.<br>[/quote]<br><br>OK, that is what I thought you meant. I have seen and used the ceramic style ballast resistors with the terminals on each end before and I thought that is what you meant.
