Positive Castor and track bar riser
JohnJohn
Richmond
I put a set of long arms on with 4 degree C bushings and have lots of castor now. I am running a 3.5" lift.
I had welded a track bar riser on before the long arms and now it is tilted back noticeably. I will try to take a picture when I get home from work but is this a problem?
I am thinking it may be if the track bar is twisted back. I would bet I will wear out the bushing faster like this.
It would suck to have to cut the riser off and reweld.
JohnJohn
JohnJohn
Richmond
That may be an easier way than cutting the riser off. Thanks for the suggestion.
dbevans2249
Buena Park, Ca.
JMO, BC Broncos Adjustable Track Bar would be best for your truck. The Hiem can be turned the way you want to releive any strain on the bushing end, it should work well. It is what I am using and I like it.
ponyracer
Crestview, Fl, 32539
If it's out to far to self adjust, pull it off and put a bend in it to help. $69 HF bender should work fine. I bent one that was 1.5 solid with one (broke the bender lol) then I just bent my new one, 1.5 .250 wall dom (after I repaired the bender lol)
