I run an HD 3 core aluminum radiator and two electric fans, one mounted at the driver's side top and the other passenger side bottom. The top fan is set to come on at 175degs and the other at 190. Both come on whenever I turn on the AC. My temps, even on a hot day with AC on, never go above about 200degs in city traffic. 90% of the time the temp is right at 190. I run a high horsepower big lift and duration cam 302 with about 385hp. What I noticed right away was the lack of all the heat when I open the hood. My old mechanical fan setup would blast me with heat when I opened the hood. I have no shroud really. Each fan is mounted directly to the radiator. They cover about 3/4s of the radiator surface. Mounting one at the hot water "in" and the other at the return gives maximum cooling for the surface covered. I only had about 4" clearance between the radiator and the pulleys, so there is no room for a shroud, even with the lowest profile fans I could find. I also run Dart Pro-1 heads and ceramic long-tube headers which also seem to retain less heat under the hood. Cooling a higher performance engine on these EBs can be a trial and error thing. My mechanical fan and shroud combo was a very tight fit and the fan would occaisionally hit the AC compressor pulley. A spacer would put it much too far into the shroud and very close to the radiator (even with the stock radiator) hindering cooling performance. The photo shows how tight it is under there.
