Post Rocky Mountain Trip Mods...
Jdgephar
I everyone! Earlier I had posted about my plans to visit Colorado, specifically Rocky Mountain national park. I first want to say the trip was amazing, and had a great time with my family and extended family, as well as with the Bronco.
I have a few things I learned during this trip, and want to share my experiences, what I found, and what I want to modify as a result.
Trip Summary:
1) Rain storms in Nebraska are nasty downpours! Why is this my first comment? Well, I drove with just the bikini top on it. I brought the full top along, just in case. However, it's sort of a pain to swap, and I was in a hurry that morning. Why was I in a hurry? I strategically stopped overnight in Grand Island, NE on the way out there from Michigan. Rockhard4x4 manufactures their bumpers just north of there in a town called St. Paul. I got up early in the morning to drive up to their factory to pick up my new front bumper (to save on shipping, of course). That morning had some nasty rain, but I got my bumper! I got a little wet, but everything dried out and I was good to go for the rest of the way out to Estes Park, CO.
https://www.rockhard4x4.com/product_p/rh-6200.htm
My existing chrome bumper is going on my '72 project once it's done. I bought this winch bumper to put the winch on my '68 instead.
2) I vapor locked my fuel system. This was unexpected, but at least I figured it out, and I wasn't stranded in the middle of Colorado on I-76. First, I should explain my setup a little bit. I'm running a 1990 mustang fuel injection setup. It's just all of the standard 1990 intake bolted on top of the 302. For the fuel, I have a Carter low pressure pump mounted on the cross-member in front of one of the old aftermarket larger rear fuel tanks. Steel line pipes the fuel up to just past the clutch linkage on top of the frame rail. From there, I have a rubber hose up to the driver's side fender where I have a 10micron fuel filter right before the high pressure pump. Output of the high pressure pump goes across the front to the fuel rail. I then just have a rubber hose going all the way back to the tank for a return line. The other hose connection on the tank is the vent line, and it follows the return line to the driver's fender, goes up and then to a charcoal vapor canister. I have the solenoid hooked up to the computer, vacuum source, and the canister.
Up until the Colorado border, outside temps were really awesome, it was never above about 85 degrees, and the morning leaving Nebraska was 65. Needless to say, everything was fine until we got to Colorado. Outside temps started going up, just as the elevation did. 70, 75, 80, 85, 90, 95...eventually it peaked at 98. Thankfully, no overheating issues. We've had plenty of hot days in Michigan and I've driven it over the highway in those conditions. The Bronco's temp gauge reads a little bit higher in those conditions, but usually around 200F, so nothing concerning. Keeping up with the rest of the convey had me doing about 80mph. With a stock three speed, that has me right at 3000 rpm the whole time. Finally, I just lost fuel pressure. Coasted to the side of the road with my brother and my dad and checked things out. First thing I could tell is that the high pressure pump didn't sound right. After years of driving it, I can tell right away if the high pressure pump has fuel and is primed, and it sounded dead. Along with that, the fuel gauge showed something like 5 psi. Immediately I thought it was the high pressure pump. I just thought that after years of under hood heat, it finally gave up. I kept a spare with me at all times, because after the first year hearing how bad it whined when it got hot, I figured it would eventually fail. 15 - 20 minutes later, had the pump swapped out and headed down the road again. Not two miles later, and the same thing happened. This time, I also noticed that I have fuel bubbles coming out of the vapor canister. That's when I figured the fuel was too hot, and the pump at the tank couldn't pump it anymore. I also had just under 1/2 tank left, so that doesn't help.
We let it cool off again, got it fired back up, and kept it to 65 the next 15 miles to a gas station. No issues, and ran just fine, but that's also only 2500 rpm. I filled up with gas, and never had another issue. The trip home only got to 90 and was able to keep the same pace as my brother the whole way home.
From this experience, there are a couple things I learned. One was to keep an eye on the vapor canister. I have a suspicion something isn't working right. Second, I eventually want to reconfigure the fuel delivery system.
I continued to notice issues with fuel vapor and the vapor canister not working right every time I climbed in elevation.
Fixes / Improvements planned: (and I welcome comments and feedback)
This weekend I did some checks, and found out the canister purge solenoid wasn't working. Vacuum wasn't getting applied at all. For now, I have it directly plumbed to a vacuum source. I ordered a new solenoid and will get it installed later this week. This for sure will fix the gas smell that wasn't getting purged from the canister.
When I originally ran the vent line from the tank, I put a loop up in the rear wheel well that goes up about as high as the filler neck. My theory was that this would keep liquid fuel from climbing the tube and going up to the vapor canister. However, I now think that this is also keeping any fuel that condenses in the hose from being able to return to the tank and is instead getting pushed up to the canister. I took the loop out of the hose this weekend. Now it just follows flat along the frame to the point where it goes up the driver's side fender to the canister. I don't know if this will be any different, since the hose still has some downhill travel along the frame before it goes back up to a height about the same as the filler neck. Comments/thoughts?
The next plans are with the fuel delivery. I eventually plan to move the high pressure pump and the 10 micron filter to the side frame rail back by the tank, and eliminate the low pressure pump. This is one less pump to fail. I will also use steel line for both the supply and return line. I would like to re-route some of the supply side better so that it's not so close to the dual exhaust in a couple places, and have less supply side fuel line up in the engine area. I also plan to get some heat wrap to put on the lines in the engine bay for some insulation. This will take out a couple feet of hoses in the engine area where the fuel can pick up heat.
