Powder coating a seat frame
nathan_1970
I'm just curious if anyone has had their seat frames powder coated?
I called a couple powder coating companies and they said it should work very good for this application even on the springs. What are your thoughts?
I searched and found a couple of threads about powder coating and from what I can gather, it isn't a good idea for areas that will be cut, welded or modified which this wouldn't.
Thanks!
Blue71
Don't do the drivers seat tracks. There is plastic parts in them that functions as the sliders. It melts it completely and ruins the track. Frames should be fine I would think.
Blue71
wesleydax
i coated my tracks. took them apart removed the plastic glides and powder coated them. they work smoother than ever.
nathan_1970
nathan_1970
Blue71
Wow! I'm glad I asked. Would a 1970 bronco front bench seat have the same plastic pieces? I don't have the seat here at the moment so I can't check for myself.
wesleydax
take a flashlight and look down in the tracks you should be able to see em
nathan_1970
nathan_1970
I actually want to powder coat the whole metal assembly frame, springs and mounts. So the last two comments showed me that i should be more descriptive. Thanks for all the comments!
