Powdercoat or rattle can stock rims
smittymike19
so im going to run a stock look on my 72. The rims that came with it are rusted on the inside but are pretty nice on the outside. I was going to get them either powdercoated or just rattle can them. I think ill be sometimes running them with hubcaps and other times without. Will taking the hubcaps on and off just wreck the finish regardless of whether they are spray painted or powdercoated? if its going to wreck the powdercoat id rather save the cash and just spray paint. Thoughts? Thanks.
Rustytruck
spray paint them. hubcaps will cut through anything you put on the wheels.
HigginsHorse
Powdercoat should stand up better than rattle can, but PC durability will depend on prep and curing. I powdercoat if I have the option. It'll look better longer.
jmhend
I think this is an option / subjective view. I can see pros and cons to both options.
Paint Pros:
Cheap
Easy to touch up
Paint Cons:
Not as durable as Powder Coating
Powder Coating Pro's:
Durable
Strong
Longevity
Powder Coating Con's:
Expensive
Added thickness that can cause a problem with valve stems, hub caps, lug nuts etc...
Not easily touched up
Just my .2
I have gone with both options. Good luck with your decision
AC932
I'd go with a rattle can. Every time you take the hubcaps off/on, it's gonna scratch it. May as well go with the cheaper option. I keep a little can of model paint and a brush in the glove box for touchups when I'm feeling really picky.
bronkenn
Bronco Guy
Southeast Ohio
If your planning on taking the hubcaps off and on I would rattle can them. Powder coating is expensive and looks really nice but those hubcaps will tear them up. I think if you powder coat them you won't want to cover them up. Plus powder coating is expensive. Cost me nearly 600 bucks to do a set.
Fastmax33
Terre Haute, Indiana
I painted mine with Duplicolor Wimbledon White spray paint and was satisfied. It is a bit more off-white than my original paint top though. I think I will sandblast and paint them with a gun the next time that I replace the tires.
Scoop
Have Bronco, Will Travel
Cuchara, CO
This ^^^
And this ^^^
With hubcaps, paint and you can touch up. Without hubcaps powder coating will look better longer. Question is, will you EVER want to put on hubcaps?
I ran my 74 Ranger for years with white steelies and no hubcaps - a look I really like. But lately I wanted the full stock appearance so I put the hubcaps back on. The wheels are painted so If I want to go back to the white steelie look I can just touch them up.
elan
s
I just did some 1950 Willys wheels with spray paint out of can. I didn't powder coat as I knew Discount Tire would chip them. Well guess what...I was right. But, at least I can touch them up. Had they been powered there would be no way for touch up.
