Jakedog
- Jan 25, 2010
- 1,010
Have you guys ever had a power brake booster break? After changing the oil in my bronco I decided to take it for a quick drive. I just started to back out of the garage, and when I hit the brakes the pedal went to the floor!!
At first the pedal came up enough so that I could push it again, but the next push it stayed down. Luckily I wasn't all the way out of the garage, and I forgot to release the E brake which doesn't work that great, but it was enough to stop on flat ground.
I opened the hood and I had my son try to move the brake pedal while I checked the linkage on the firewall. He couldn't move it. It was literally stuck to the floor. I told him to try and pull the pedal up. When he did, the push rod going into the booster came loose. When I pulled the black boot back from the rod I could see that the booster itself had broken. Like it pulled the piston out of it or something like that.
I don't know all the part names on the booster.
The booster came from O'Reillys about 4 years ago. I've never had a booster break like that.
