power brake conversion help
EBatl
Atlanta, GA
I am installing a power brake kit on my truck with 4 wheels drums. It came with a new bracket, booster, master and all the linkages as well as a proportioning valve. Since I don't have an easy way of making brake lines and I don't want to pay someone to put the components on I figured I would put it together without the prop valve and I could then drive it to the shop to install the valve and make the new lines. I expected that with 33's and drum brakes that I wouldn't have much chance of locking up the tires anyway...
So it goes together fine, pedal travel feels normal with the engine off, and then when I start it the brake pedal actually moves down with my foot off of it to the point that it engages the brakes. Am I wrong or is it abnormal for a brake pedal to move down over an inch without touching it when you start the engine? If it IS normal for the booster to pull the brake pedal in by itself then I will look at all of my adjustments again (even though I don't really have much adjustment left, I made sure there is a little play between the booster rod and the master). If its not normal what is causing it? Too much vacuum? Is there a spring in the master or in the drums that is supposed to overcome the boost? The lack of the prop valve which is supposed to act as a restriction in the brake line (if it is?)? I've done lots of brakes and changed lots of boosters/ masters but this is the first time I have added power brakes to a car. Any help is appreciated. Thanks
Chief Master Sergeant
Retired U.S. Air Force
I don't think you need a proportioning valve. Mine had a strange feel to it after I installed the power brake setup. I experienced something similar, but it didn't affect the braking at all. If it does it now, I don't recognize it.
E
EBatl
Atlanta, GA
its not just a strange feel. the pedal moves down and engages the brakes when I start the engine. I can't drive it because they drag. I can be parked on a hill in neutral, engine running, and the truck wont move. Turn the key off and I start rolling backwards
707Bronk
You could have a defective booster???
I have heard of people having booster problems, but it is usually a leak in the diaphram.
SDlivin
San Diego
If you have a vacuum gauge, check the hose that you are feeding the booster with.
good to know what vacuum pressure you have.
If there is a leak you can usually tell because your engine idle will drop, doesn't sound like that is the case.
Also try pulling hose of booster, plugging that end and booster check valve. Now you are pretty much running manual brakes, same problem? Then it's probably not that booster vacuum causing the issue.
good luck.
