Do you know if it’s a stock box? Are your body mounts original and sagging?
Even a stock box is a tight fit coming out the bottom, so yes more likely it’s easier to pull it out the top unless you can flex the sheet-metal of your wheelhouse without bending it.
A larger aftermarket box would be even harder.
Stock boxes are close to the radiator and core support, but those should not interfere with it coming up. Once you have the shaft pulled back and out-of-the-way, the pump is definitely in the way, but I thought you could remove them without having to remove the pump first. Been a while for me, and most of them have been partially disassembled anyway. So I don’t remember what was needed.
So yes, what you’re running into is the typical tight clearances of a bronco engine compartment. But I’m sure someone else will chime in with some tricks. If it were me I’d probably find it easier to remove the radiator. But it would be messier because you can often remove the power steering pump and sometimes move it over to one side without draining.
