Eoth
- Mar 10, 2004
- 1,692
I'm adding a powered fan to my power steering cooler. I am using a thermal-switch to turn it on and off. Does anyone have a recommended temp that the cooling fan should kick on (Off is 15 degrees cooler than the on set point)? What temp do you suggest I have it set at to turn on? I know that I could use a low temp and have it run all the time but I don't want the extra fan noise when it isn't needed.
Thanks!
Thanks!
