power steering cooling w/ hydroboost
saxman
Austin, TX
I wanted to add just a small B&M cooler in front of the main radiator for my power steering. I just wanted to make sure it was ok since the hydroboost is plumbed into the system as well. I would think it would be fine.
saxman
saxman
Austin, TX
Looks like you can put a plate cooler between the steering box and pump via the return line. someone confirm, just a small little cooler should do the trick...
tasker
all knowing of nothing
NH
used an old trans cooler for my swap.....drive for a while and feel it....lots o' heat being disappated
