Power Steering Pump Pressure Hose
keesyj
I've got a 74 with what I believe is the stock power steering pump. It is leaking from the high pressure hose at the back of the pump and I'd like to replace it but am struggling to find a replacement.
I bought the Power Steering Hose Kit from Tom's and the hose bend is close but not exact and the length of hose is too short. Other options I've found are similar in length as well.
How do I identify the power steering pump? Any paper markings are long gone and I've not found anything stamped in.
AM-JKLUzViNMilcnfeMAL29fq5HF3F2EzkgcAtWvWSPCUbwKdI3yWoy61hfVgCTe0zmf4BJt2fzdhCVOjxuuUia6_vc5vc-v9HoFUsk3agiAM0sOMOmHc8f00jNYXv7mYEloT9UUiFSq_b6WWrNW7L5Jv3KIGg=w1814-h1360-no
AM-JKLUcYa30dzpqsflgHT0iH7_9unupRIlj87_rtSIQQwpDeCqHRirgQTDKL6u_YAQUu6J3YiG8QUK-Gp5unO5anD3AGQTLqduFezovNSJbxlV1-WInpuHPWMJO8gBoODvpHw66rQFhL-q4QH_cF26HykDJmA=w1814-h1360-no
AM-JKLWNzWvJq_-IdkL3VmLN282fioCihv8N6Gw2a9qUyf_86ge14xez2LR_cz4doBZTDfmLbXKjQdL4rF5Gnp2VtButYPEw5exFKSayYZ0Y4qu9Jzv-vbPzqXM1DhqFvawUyWqjV_lajqTTu7q0NWy_2KC37g=w1022-h1360-no
AM-JKLWHjLe50frLXpbXoescrjyRssOJwGaszxMLoFdGI947eR9ApRc1B3QX6muzBmXn7EqFpwHIkvWk5ZlYVsKqGgpuIXnmidk8J6dtZR5ZOKoDMKoF6LQyD7PG7qTUXmqb87cmjIKaClAbn5lQNCMoJ7qHjw=w1022-h1360-no
AZ73
I went to a shop that makes custom hoses and they made me one for $40.
Jdgephar
It looks like a stock pump. My hose doesn't look exaclty like that, but the rockauto replacement hose worked fine for me. Probably can't route it the same way as your current one though.
Sent from my SM-G981U using Tapatalk
Jdgephar
I've got othet crap in the way, but hopefully this gives you an idea...
thegreatjustino
Red Head Grease Monkey
Stockton, CA
You have a stock pump. You just need to route the replacement hose differently.
Pa PITT
Stephenville TEXAS
Back when I had my parts store I made P/S Hose . so I say take yours to a quality parts house & ask them to make you a hose.
Some times on AC & p/s hose I've made half the hose & gave the customer the 2nd fitting .Telling him to take it home & Mark the Hose the best length he needed. Then put a couple of marks on the fitting & Hose best placed for proper fitting . THEN I'd cut his hose & 2nd crimp the new hose.
... Some of those hoses are so stiff you can't bolt them in place if their crimped wrong. Or their just alwayb in a bind.
