Power Steering Pump - Tutorial?
Jc.av8r
I did quite a bit of forum searching last night on power steering leaks, but couldn't really find what I'm looking for here or on YouTube.
Does anyone know of a FAQ thread or a decent DIY tutorial on how to take care of my power steering pump leak?
I'm going to try and fit new hoses and clamps to start with, but thinking I might need to just put a whole new pump in. Never done it before and not sure what pump I should buy or how to swap it out...any help?
ransil
if going to swap get a power steering pulley puller, do not use a 3 or 2 'claw" puller.
become a contributor and post a picture of what your working with as all our Broncos have changed so much all these years.
Didn't you post a pic of your return line all swollen and leaking in another thread? Or was that someone else?
If it was your thread, you should keep it there so there are pics and other descriptions. Sorry if that was someone else.
But basically, almost any leak can be stopped. But if your hoses are leaking, it's almost always a matter of just changing the hose. Sometimes the fittings leak, but often can be fixed by cleaning and dressing the seating surfaces. These things were made to be pretty leak free through the clever use of some pretty well designed fittings.
The return line is just a hose fitting on the pump reservoir and you simply put the new hose on and clamp it down. The hose I saw in the pic looked either pretty old, or was of the wrong type of material and had deteriorated. But did you try tightening the clamp first? Just to slow it down temporarily at least?
If it's a damaged reservoir leaking around the pump, or an o-ring giving up the ghost, you could probably find a youtube tutorial on how to remove the reservoir and replace the o-ring. But at that point, most of us feel that the pump just might need replacing so you have all new and good working parts and don't have to do it all again anytime soon.
And if you have an old Ford pump, many will "upgrade" to the Saginaw/Delphi "Canned Ham" style pump.
The early style pumps that would have come on an EB (steel reservoir, tiny filer neck, steel dipstick) were not that good and are near impossible to find new. The later style found on the full-size Broncos (plastic reservoir, larger neck and plastic dipstick) are actually very decent, but nothing special.
When using larger tires, hydro-boost, or other fancy plumbing setups, the GM-based Saginaw pumps that we all sell are definitely an upgrade. Compact, powerful, reliable, steel reservoirs (or remote reservoirs) and easily available, customizable to have even more power if desired, high flow rates, and relatively inexpensive brackets to bolt them on to our engines with, they're the more desirable pump.
I forgot to mention the "fun part" of all this. Bleeding the new setup!
It's not always such a big deal of course, but over the years plenty of us have had to adjust the procedure to fit out needs that it bears mentioning.
The book says to lift the tires off the ground and turn the steering wheel back and forth about ten times to purge/bleed the air out of the lower parts of the system and into the reservoir top. Well, that's not always enough.
Maybe the Delphi pumps are just better, because I have not heard of it as much in the past five years or so, but many of us have had to do the wheel turning thing upwards of 100 times(!) to get the air purged out.
It eventually works 99% of the time. But you have to be patient sometimes.
It then becomes a "have fun and whistle while you work" process.;)
J
Jc.av8r
So on closer inspection, it's not just the return hose that's leaking, but also seems to be leaking out of the threads from under this large bolt on the back.
Is there an easy way to seal that up or do you all think I might just want to throw a whole new pump in there and be done with it?
It seems like a relatively simple process -- bolts and hose fittings...If I do remove and replace the pump, what do I need to do in order to get this pulley off and on easily?
http://www.stangerssite.com/HowItWorksFordPump.html
Where the leak is on the back of the pump there is a big nut on the back of the housing the holds the housing cover on the pump. Inside the pump there is a seal that is under the nut and the cover. make sure the nut is tight. otherwise you have to pull the cover housing off to replace that seal and the large O-ring that seals the housing to the pump body.
J
Jc.av8r
This is exactly what I have been looking for. Thank you!
