This will take awhile…..
So my power steering worked fine but after rebuilding my front end I figured why not overhaul the steering. I replaced my power steering box with a new box from Tom’s and all was well. Then I thought, since I have the original box, why not get it rebuilt? I sent it off, got it back, and it worked until I drove a few miles and then gradually lost assist. Let it sit and it is fine until I drive again. WTH?
So I checked with the pump rebuilder, and at their advice replaced the pump. No difference. Put the Tom’s box back and it worked fine with the new pump. Put the rebuilt box back in, put a gauge on it and the new pump is putting out 1400lbs with the wheel locked when it is cold. Drive it for a few miles, repeat the test, and I see 700lbs with the wheel turned partially which feels like no assist. 10 minutes later I see 1000, then later 1200, then back to 1400.
Next step is I sent the box back to the builder to test and I tore into the old pump just to verify the valve was not stuck and look for wear. It looked fine. So now I get a call from the builder telling me they tested the box and it looks fine..
So to sum it up:
Original box worked fine with original pump.
New box works fine with original pump.
Rebuilt box doesn’t work with original pump.
Rebuilt box doesn’t work with new pump.
Builder can’t find a problem with the rebuilt pump.
The odd thing is that it only happens with the rebuilt box and only after driving a few miles.
Anybody ever seen this?
So to sum it up:
