Power steering woes….
Slowleak
Georgia
This will take awhile…..
So my power steering worked fine but after rebuilding my front end I figured why not overhaul the steering. I replaced my power steering box with a new box from Tom’s and all was well. Then I thought, since I have the original box, why not get it rebuilt? I sent it off, got it back, and it worked until I drove a few miles and then gradually lost assist. Let it sit and it is fine until I drive again. WTH?
So I checked with the pump rebuilder, and at their advice replaced the pump. No difference. Put the Tom’s box back and it worked fine with the new pump. Put the rebuilt box back in, put a gauge on it and the new pump is putting out 1400lbs with the wheel locked when it is cold. Drive it for a few miles, repeat the test, and I see 700lbs with the wheel turned partially which feels like no assist. 10 minutes later I see 1000, then later 1200, then back to 1400.
Next step is I sent the box back to the builder to test and I tore into the old pump just to verify the valve was not stuck and look for wear. It looked fine. So now I get a call from the builder telling me they tested the box and it looks fine..
So to sum it up:
Original box worked fine with original pump.
New box works fine with original pump.
Rebuilt box doesn’t work with original pump.
Rebuilt box doesn’t work with new pump.
Builder can’t find a problem with the rebuilt pump.
The odd thing is that it only happens with the rebuilt box and only after driving a few miles.
Anybody ever seen this?
Slowleak
Slowleak
Georgia
Are you using synthetic fluid?
No. I thought about that but I hear it can cause problems. I’m running standard PSF and have been thru about a gallon of it….pulling pumps and pulling boxes. Bled it like there is no tomorrow.
Bruners4
1/2 way to everywhere
Any HYD pump will not create pressure without a restriction of some sort. The steering box is creating the restriction that causes the pump to build pressure until the pump's pressure relief valve limit is reached. I would be looking at the steering box for an internal seal bypassing or the valving not demanding the pressure to rise. Internal leaks are real and very hard to find.
Slowleak
Slowleak
Georgia
I don’t know how they are testing box but it seems to me that when it heats to a certain point it could expand and leak around a spool valve seal or the sector shaft could bind up. I spoke with them this afternoon and they know they have to change something. They are going to replace the spool valve and doublecheck the ball sizes that they installed. They are easy guys to work and they paid to have it shipped back. I just hope they figure it out.
PNW
Stock PS system correct? No aftermarket reservoirs, aftermarket cooler or hydroboost or hydraulic ram, correct??
Slowleak
Slowleak
Georgia
All stock. Ford-Thompson pump and original Saginaw 4 turn box. The other pump is a Lares and the second box is the stock style replacement from Tom’s.
ntsqd
heratic car camper
Upper SoKA
When I put the H-B PS system together on my FSB it cavitated the pump at idle. I was using generic PSF in it. Tried a bunch of things and no change. Read a thread on Irate about PS systems and it was possibly there where I ran across the suggestion to use only ACDelco 10-5073 PSF. Figuring nothing to lose I tried it. Cavitation stopped, system has worked well until recently when I topped it off with some other PSF because I'd run out of the 10-5073. I reasoned that it didn't need much and that I'd be OK. It isn't, the system cavitates easily when asked to run both the brakes and the steering.
Things to know about my system: Saginaw pump rebuilt by Lee PS for H-B use with a remote reservoir. Std FSB PS Cooler, generic rebuild PS box (A Lee rebuilt is waiting for my time to install it), and a Vanco H-B kit.
I'd say order some 10-5073 PSF and give it a try, but you'll want to remove as much of the old fluid as you possibly can. None of my LAPS carry it, I've been having to order it off of Amazonain Auto Supply.
Slowleak
Slowleak
Georgia
Thanks. It’s a good time for me to switch fluids and stick with one. I just put the original pump back together with new seals and have not installed it or filled it yet. I also have a few sets of new hoses.
It’s Lee that is doing my box. I’m hoping they can finish it up Monday and I will ask Mike what fluid they recommends.
The last I used was Fram which the label says is compatible with Ford ESW-M2C128-C which Google told me is a Ford power steering fluid specification for older vehicles
ntsqd
heratic car camper
Upper SoKA
I was just going to ask that question, what does the Thompson pump want for fluid? Not merely what meets the spec, but what was the original fluid and is it still available?
If it were a Toyota pump I'd tell you that it doesn't want PSF at all, it wants Dexron, but that's an outlier.
Slowleak
Slowleak
Georgia
The 1977 Manual says:
Power Steering Fluid
Ford Part# D6AZ-19582-A
Ford Specification - ESW-M2C128-D
I don’t know if the specific Ford fluid is an available but there are plenty of brands which are labeled as meeting those performance specs. Even the cheap stuff at O’Reilly’s..
