power steering woes!
4x4man514
Augusta,Georgia
im at my wits end guys. dont know what else to do .my power steering hardly works at all.even when im rolling at 5-10mph.the belt squeals anytime the wheels arent straight.i have put 2 new boxes on.the last is a agr box.i have replaced 6-7 pumps.ive replaced the hoses, completely flushed the system with new fluid.and the belts are tight.ive raised it off the ground to check for interference and it turned smooth as silk.i only have 35s so it shouldnt be that bad.my other truck has 44s and turns like a dream so i know its not the tire size.am i supposed to give up?has anyone else had this problem?it is a 72 so it didnt come with PS but i wouldnt think that woould matter.please help guys.yall are my last hope!thanks kevin.
svens70
Oregon, IL
Have you tried turning it with the front tires off the ground? Put the front axle on jackstands and give it a try. Even if it does it without squealing the belt, feel for binding while turning the wheel. You may have some bent linkage.
md_lucky_13
Idaho
"it is a 72 so it didnt come with PS but i wouldnt think that woould matter"
Might be a long shot.. But what kind of brackets did you use? Did you make sure that everything is lined up perfectly? If they are off a little, it might cause some of these problems you are talking bout. Maybe take a level to it and check? I could see it causing the pump to wear out very fast, and I could also see the whine, but I don't know about everything else...
Once you have checked and replaced everything at least twice, go back to the easiest point and check it again. Chances are, this is where the problem came from. :p
