Primer for single stage paint
JWMcCrary
Is there a primer that comes in a spray can that can be used under single stage paint? Going to be a while before paint and need something that can be sanded and prepped without having to get it all off later, if possible.
If it sounds like I don’t ‘now what I’m doing...congrats, dead on.
My generic answer would be to stop by the paint supply shop where you will buy the paint at and ask them. That way you know you will have a compatible product for the final paint. Not everything is compatible. When I had my last project painted the body shop that was spraying it had the line of paint they use, and all the stuff that goes under that paint is in the same line and all compatible. For me it was simply picking up the right can of matching material and shooting that at home, did the last of my work, and turned it over to paint. They knew what was on it and it was a compatible product.
Guessing you may not be that far ahead right now. I think what you need is more of a sealer than a primer. But I am no expert either. I want to say that many primers are porous so the steel can rust under the primer if you leave it out.
JWMcCrary
JWMcCrary
Planning to use paint from Summit and was going to ask them, thought i would get some opinions from here as well. I think you are probably correct on sealer vs primer. Was hoping I could get some spray cans for the time being to take care of my needs, will be a few months on paint.
fordguy
I am buying some epoxy from English paint supply in Jackson for bare metal
markw
I've used SEM high build primer in rattle can under all kinds of paint with good results. I wouldn't leave it uncoated for long though.
