Programming a EEC-V or EEC-VI computer
Boss Hugg
Surely in the nearly 20 years that they've existed, someone is able to program a computer from a 94 up Ford truck for use in our fuel injection swaps so that we don't have to dig for those certain computers that work best in the EFI swaps. I'm thinking Troyer Performance?
All they would have to do is disable any extra controls such as air bags and traction control or ABS.... All we need are the basic functions of controlling spark and injectors.
Anyone have any experience doing a non EEC-IV swap? I've read through a few posts about 4.6 swaps, but the ones i read never got to the controls, or they were going the quick and somewhat expensive route of the Megasquirt..
EEC-IV takes a chip very nice.
Trouble with the newer stuff is Ford started changing stuff all the time. It is common to find a vehicle that was built with this but before that was added and end up with a computer that is only valid for the 6 month build window that spans 2 model years.
I know of shops that can reprogram the computers. Just about any SCT shop should be able to do it. But they tend to deal with engines in there original applications.
The early OBD-II computers were easy enough to replace with OBD-I (EEC-IV computers) and get an engine up and running nicely. Later the computers got a lot more complicated. CAN databus makes life interesting. At this point you are no longer dealing with simple voltage or pulse signals that are easy to replicate or fake. You are now talking in computer language. I love the Ford tech telling me about trying to chase a problem and unplugging the meter and the engine won't start. Plug in the meter, start the car, unplug the meter and the engine dies. The documentation isn't the greatest on what all needs to be where.
I have helped with some engine swaps (on other makes) with modern engines. It is interesting to hide an extra insterment cluster in the trunk to get stuff to run. Putting 4 ABS sensors all on the same drive hub to get all 4 signals to the computer to make it happy. An ABS pump dead headed and never sees a brake light switch to tuen it on. And you start with a whole running donor and carefully take stuff off and keep checking. You can whittle away a good chunk of stuff, but you would be amazed in what you still need. I know of a Ford Focus swap (into a Bronco no less) that was a pain because there was a loop of wire under the drivers seat that needed to be intact. The wire didn't go anywhere, it was just a loop. But without it they couldn't pull codes to figure what was wrong. And since it was a swap the factory service manuals were not exactly a match.
That old stuff looks so simple and easy to understand. And it works just as good.
lowbush
Summerland Key, FL
I write code to put food on the table and do some embedded development. Needless to say, I have thought about what it would take to redo some of these things and the reality is, when you start swapping stuff around it would be easier to replace the ECU than to write code for every possible ECU out there that could be used. I was thinking about using an Arduino board for this because they are cheap and used by a lot of hobbyist for all kinds of embedded projects. If someone built it modular then all you would have to do is write a driver for each interface and build an adapter for the harness, it would still take some custom programming for each configuration, but it would be a heck of a lot simpler than trying to modify every possible ECU out there. Many of them have totally different architectures and instruction sets which would make modifying them a pain. getting everything over to a unified and modern hardware architecture would make it a whole lot simpler.
Steve83
EEC-V is OBD-II ('96-up). I don't know if they've gone to EEC-VI yet. ~'83-95 trucks use an EEC-IV.
There is no traction control, ABS, or SRS in the EEC/PCM; it only controls the engine & trans. ABS & TC are in one module; SRS is in another.
Boss Hugg
Boss Hugg
Careful, KLS, you're starting to sound like me in my Algebra 1 classroom. Use too many big words and you'll scare everyone off.;)
This really makes the mega squirt sound good, but the prices I saw... I'll be trying to find a crown victoria or t bird on the cheap. Their probably more easily found than the mustangs.
lowbush
Summerland Key, FL
Yeah, I was just really putting a bunch of garbage in my head down in text. But the point was, it becomes more practical to just chuck the hardware and use common hardware and then build adapters to adapt to the different components out there.
The megasquirt is probably the best bet but there are some things that I don't like about it. while they tried to make it modular, you end up having to use some recommended parts or else you have to reconfigure the code for the parts you are using. The other issue is that is does not support direct injection engines. Not that big of a deal for the older stuff, but a lot of newer gas engines are going over to the common rail and direct injection like the diesels did. I honestly think it could be done better than megasquirt did it (not taking anything away from what they have done) and make it work with anything that you throw at it. I personally thought about doing one because I am a diesel guy and I would like a hackable common rail controller and if I was going to do it I would do it on the hardware I mentioned before because there are so many people using the Aurdrino hardware.
