Well it has been a few weeks after the sale of my steam locomotive project. I am now fully focused on the Bronco. I thought I would bring up my old list of upgrades, from post number 1 of this thread. And see how close it compares to my wants for the Bronco today.
Post #1
My plans for the 76.
Upgrade the Bronco to be more road worthy and comfortable for long trips, along with upgrades to improve it's off road capabilities for light to moderate trials. I want to be able to drive the Bronco anywhere from coast to coast, to attend as many Bronco related events as possible.
Here's a brief list of the future major upgrades, in order of priority.
Adjustable track bar. (Already purchased)
Wild Horses, 2.5" suspension lift kit with Bilsten shocks.
"Y" to "T" steering linkage upgrade.
New wheels and tires. Following the vendor mass buy, for 17" x 9" MHT Indy slots. http://classicbroncos.com/forums/sho...d.php?t=236592
And looking at LT315/70R/17 Goodyear Dura Tracs.
One inch body lift.
Body repair and repaint to original colors with new decor stripe, and color matched Bronco design fiberglass flairs. I'm also in the process of upgrading to the Sport trim level. I only need to install the grill trim and the Sport badges, which I already have. Sport interior upgrade will come later.
Plate bumpers, front with winch and rear, featuring tire carrier, and possibly fuel can and cooler racks.
Rocker protection.
Explorer EFI 5.0 engine and 4r70w tranny upgrade.
Twin sticks.
Vintage air AC.
I have to say the list is still pretty relevant. I haven't changed much from my intended usage, other than being more focused on Overlanding Exploration. So I'm still look for reliability, comfort and capable to drive anywhere any distance in all conditions. What has change on the list is my choice of components. Over the last few weeks I have been busy ordering and receiving parts for the upgrades. So here is what is on order or has already arrived.
2.5" Duck Tuff suspension package
Long tube ceramic Headers and at a later date an exhaust system
Tom's Bronco Parts
Dana 44 rebuild kit with new chromoly axles, heavey duty u-joints, 4:56 gear set. and ball joints.
Ford 9" rebuild kit with new 31 spline axles and 4:56 gear set.
4R70W to Dana 20 adaptor and cross member
Twin Sticks for AOD transmission
23 gallon EFI tank with in tank pump and skid plate
3 core reverse outlet aluminum radiator
New plate style 6 point family cage
Wild Horses Motor Sports
Dana 44 ARB Locker
Ford 9" ARB Locker
ARB compressor
Saginaw dual return PS pump with serpentine pulley and bracket
130 amp 5.0 alternator
FlowKool water pump
Extreme Motor Mounts
Aluminum radiator shroud
Ruff Stuff
Dana 44 diff cover
Ford 9" pinion guard
Ford 9" spring perches for axle moved back 1"
The 96 explorer 5.0 will be off to the machine shop in a few weeks for a rebuild with a new Comp Cam K35-349-8
4R70W is on the waiting list at local rebuilder
And I have been in contact with Garry (EFI Guy) about the wiring harness and PCM re-flash.
Now to get started with the tear down. I'm going to pull the body off the frame. Blast rebuild and repaint the entire drive train with the parts listed above and more parts to come. The body on my 76 is very, very solid. So for now I'm only going to address the rust at the inner fenders clean it up keeping the original patina. Although I prefer a shiny paint job. I don't have the funds to go full out with a paint job. And I don't want this to turn into a multi year rebuild. I want this back on the road ASAP!
Sorry for the long winded post and thank you for following along on my journey. I'm sure I will be hitting you all up for help and advice. This will be my first attempt at a project like this.
Regards,
Fred
Post #1
One inch body lift.
Rocker protection.
Twin sticks.
Vintage air AC.
Tom's Bronco Parts
Dana 44 ARB Locker
Ford 9" ARB Locker
ARB compressor
FlowKool water pump
Ruff Stuff
Dana 44 diff cover
Regards,
Fred
