crawln68
- Oct 8, 2004
- 3,045
dtw said:This thing looks awesome! Nice work on all the floor pans and fender stretching looks real clean.
I have a 1970 which i am going to put a '78 F-150 4x4 steering box into, hooked up to that i am going to drop a saginaw pump in from a mid '80s econoline.
If you had some pictures of your p/s setup that would be sweet. Also any tips or helpful information is much appreciated. ;D
Keep up the awesome work.
Here are some pics of how I mounted my F-150 4x4x2 box and Saginaw pump. I reinforced the frame with some 3/8 plate on the inside and outside and then ran some DOM tubing through the frame for the bolts to go through. To mount the pump I modified the stock Crown Vic bracket to accept the Saginaw pump. I also welded in a second return line into the back of the Saginaw reservoir. Hope this helps.
