Project Grabber Orange
half cab
Guru Bronco
Knowing how ole SnS operates he may have put that in there on purpose..
bbow
bbow
Ozark, Alabama
Who know's. I have worked on brakes for about 4 weekends in a row. One day soon I will have all the problems worked out (of the brakes).
br0nc0xrapt0r
Loves pickles
Finished all the loose end on the exhaust. Not beautiful but I did it myself. I am sure I will make some changes in the future.
I recommend changing it now. That is is worst place IMO for the exhaust to dump on a bronco. I made the same mistake and killed a lot of brain cells.
sprdv1
REBEL
That just resonates off the ground too, Mine is "Loud" uggh..
br0nc0xrapt0r
Loves pickles
Funny how we get older and don't like that anymore? I thought it was cool 5 years ago when I did it.
BBOW, Look at my build thread and you will see where my exhaust exits now. It needs to come out about another 3 inches to be perfect.
bbow
bbow
Ozark, Alabama
Looks like you did the exit right at the front of the rear wheel. I will probably roll some 45's out in a similar fashion to keep it simple.
bbow
bbow
Ozark, Alabama
Installed roll bar extensions this weekend. These are off of a jeep yj. Picture is not so good.
Sent from my DROID RAZR using Tapatalk 2
bbow
bbow
Ozark, Alabama
Took the Bronco out for a drive today for the very First time. Broke down on me in walmart parking lot. Would not start. Killed the already questionable battery trying to get it going. Fortunately the auto repair guys hooked me up with a new 700cca battery. Still have some fuel issues. Seems like vapor lock. I don't think my tank is vented. When you remove the gas cap it will nearly blow it out of your hand.
bbow
bbow
Ozark, Alabama
Installed a new (to me) steering wheel. Took the Bronco out for a drive. Steering gear box is leaking really bad. Radiator now has a pinhole.
bbow
bbow
Ozark, Alabama
Was your first thought....It's the great pumpkin charlie brown!!! I had worked on it most of the day running the exhaust all the way out to behind the rear tires, changing oil and such. It's still a double handful to drive. Ordered a track bar riser friday. Still trying to get the front end dialed in.
SP66
You should be proud--with the hand that was dealt and all--keep plugging away;D
beaux312
Hartford, AL
If you have a stock pittman arm it will fix you driving issues, it will line up the drag link and track bar. But the riser would be a better choice.
bbow
bbow
Ozark, Alabama
Installed the duff track bar riser. Drag link and track bar are nearly perfect. Bump steer is gone. Unfortunately it still wanders all over the road. Back to the drawing board.
mudstud
Bronco Bonehead
Excel
A couple of things come to mind on that worn tires or caster.
bbow
bbow
Ozark, Alabama
Tires are practically new. I have not taken it in to get the alignment checked. That is my next move. Have dropped radius arms but I am not sure what degree bushings are installed.
