project " insane in the membrane " 4 link build
W
walls
Wow that truck has come a long way since I sold it to you. I still kick my self in the ass for selling it. Looks great!
Thank you, you wont be disappointed with it when I post the final pics. The body is going to appear the same as it was when you sold it. We always loved the look of the truck, just wanted it a little bigger and better.
W
walls
W
walls
4 link bars complete, rotors, calipers and hubs all installed, sway bar finished up all in a weekends work. Need to finish plumbing brakes, some wiring and install cable twin sticks and body will be ready to drop back on. Sounds quick on paper but something tells me it will be another month before the body sees the frame.
W
walls
Completed plumbing brake system minus the master cylinder, that will get done when the body is put back on the frame. Bending stainless steel tubing is no party and I found out the hard way that it does not get double flared. I did some research after noticing small cracks in my flares that stainless steel does not get double flared. That being said I wasted an entire day remaking the brake lines because of the cracks in the flares
W
walls
Started on some wiring also, when you get to the wiring part of a built you can finally see the light at the end of the tunnel.
rguest3
Curious. What Springs Rates did you go with on your Front Coil-Overs?
sprdv1
REBEL
Looks good.. Nice and clean
W
walls
To be honest I forget. I put the truck on 4 corner scales and gave the info to ben at filthy motorsports and he took over from there as far as building the coilovers and spring weights. I'll have to check and get back to you
W
walls
Console complete
Console complete,
W
walls
Wiring complete after about 40hrs total. Every connection crimped and soldered.
W
walls
Hydroboost completed only had to make about 5 trips back to the shop that makes my custom high pressure lines to get them all how I wanted.
W
walls
Different tires and rims mounted and balanced ready for maiden voyage any day now, been saying that for 3 weeks but its really any day now for real
W
walls
Transmission fan and cooler plumbed and wired
W
walls
Few more things to finish up and its finally time to ring this things neck after almost 5yrs of down time.
sprdv1
REBEL
Awesome... good luck with that maiden voyage and hope it's smooth sailing
