Project Springtime or Busted!!!
stupidboy
My wifes porn star.
Morrisdale Pa.
Slowly but surely gettin stuff done. Also got classic plates for it yesterday so the inspections are a thing of the past for now! ;D
The mirrors are off of a 67-68 mustang. At least that is what it said on the box. Here is a pic of the driver side mounted up. Now my DAD is saying he doesn't like them. Says they don't look tough enough! %)
I kinda like them but curious what ya'll think of them! :cool:
Those mirrors look like the factory one on my 72, it only has one on the drivers door and I wondered where to get a match for the other side. Now I know.;D Those look great on there by the way.:cool:
broncoitis
broncoitis
;DThanks guys! Not really sure about them just yet. I have to drive the truck on the road to get a better opinion. I like the way they look as well just wondering if they are a bit small. The other factor that I am currently dealing with is the fact that my seat is sitting a bit too high and it makes seeing what is in the mirror a bit awkward if that even makes sense! %)
Gonna reserve judgement for a while till I get some of the other stuff worked out.
As for the FJ Mirrors, I really like the looks of those as well. However, I have seen that they are pretty expensive. That may end up being the final direction that I take with the mirrors. I mean a toyota has to be good for something right?
Stutsmo
Those mirrors are just fine they look Awesome and gives a classic look to an EB with a modified appearance(cut wheel wells, Bigger tires etc….). Who cares if you can see out of them they just look good!;D
HGM
Senoia, Ga.
Those mirrors look pretty good.. I'm leaning towards a mirror that I can paint body color though, on mine.. Gotta say, I cant get used to the FJ mirors, hate the look... Plus, I'm pretty anal about the fact there will be no Toyota parts on my property, let alone on my Bronco. But, thats a different story... So, I've noticed the Miata mirors appear to be pretty close to my vision.. I'm not to that point yet, but I think they'll look pretty good.. Part of your issue may also be that the mirors are set so far back on the door.. Not sure how far they can be moved forward, and still be able to see past the vent window frame, or if you even want to go that far with the doors already painted, though...
stupidboy
My wifes porn star.
Morrisdale Pa.
Yea, for the people that drive a toyota. Those mirrors you got are going to look very good and best of all they are original equipment for a ford early bronco. Helllooo!;D
broncoitis
broncoitis
Im just messin on the good for something part becasue I drive a Camry! :eek: Car has been good to me and I plan to drive it into the ground.
Actually, the mirrors are off of a Mustang! 67-68 to be exact I believe.
I like them just not totally sold yet on them just yet. They could be a bit more forward on the door but moving them would most likely affect the function of the vent windows.
But yeah, they do look good to me right now just gotta play with things and see how they work out in the end. :cool:
broncoitis
broncoitis
Greg,
I actually thought about partially painting the mirrors to tone them down a bit but I kinda like the BLING factor. Still might do it though. Matches the Chromed Bronco Script on the front fender nicely.
I agree with the mirrors being a bit too far forward. %)
The Miata Mirror sounds interesting but how would it fit and what year were you thinking?
broncoitis
broncoitis
HGM,
Fair enough! I see your point on them but of all the mirrors I think those possibly look the best and they overcome the fact that the original mirrors are mounted so far forward. However, even with the FJ Mirror the rear most hole on the door will have to be patched I believe. I measured the mounting base on an FJ and it wasn't wide enough to cover that back hole. :(
HGM
Senoia, Ga.
Greg,
I spend plenty of time on the road in my commute and see plenty of cars... So, I kind of make it a hobby to look for things that might fit my project;D.. Anyhow, with that being said, I've noticed the Miata mirrors typically mount on the same surface, similar radius to the Bronco. I have only been able to look at '10 and '11 up close. But, the best I can tell, even back several years could be a potential donor... Sorry I cant be more helpfull there. Like I said, I havent gotten to that stage yet so, its on my to-do list and thought I'd throw it out there for thought since you're kicking things around..
Totally agree on leaving the Mustang mirrors chrome though.. They do look good as is..
HGM
Senoia, Ga.
Greg,
Here's a pic for you Rob....
broncoitis
broncoitis
Greg,
Those definitely have potential and it does look like they would possibly fit the contour of the body. Gonna stick with the Mustang mirrors for now though. I will see how they work out after I get the seat mounted to the floor and off the cage. Sitting a bit high right now and that is definitely effecting how I look out at the mirror. Got my fingers crossed nonetheless. ;D
broncoitis
broncoitis
Main & Fuel Pump Leak!!!
Well, as I have mentioned before, I have a REALL SMALL leak in the external fuel pump and another SMALL leak coming from the pickup area on the tank.
Have tried to get the leak to stop with no success and I have had enough. Thought about buying a new EFI tank from one of the vendors but honestly too expensive! So I built up a new tank from scratch.
Finished the tank up tonight and all that is left to do is fab up some brackets to mount the tank under the truck and wire up the pump and sending unit! Hopefully I can finish it up this weekend but will probably have to wait till next week.
On a different note, having some issues with the motor. Seems to be leaking coolant. However, the frustrating part of the whole thing is that it doesn't seem to do it all of the time. %) Boy I hope I don't have to pull the whole engine and go through it. That would be a real Bummer! :( Unfortunately the only way to learn stuff is to just do it and I have learned a whole lot on this project. :cool:
Forgot to bring home the camera but will post up some pics of the tank tomorrow for those interested. Looks similar to the tank that Pat built. Mine came out good but Pats came out better I think. Hopefully no leaks! ;D
stupidboy
My wifes porn star.
Morrisdale Pa.
Well without pics its hard to tell, what were you thinking mentioning a contest like this without pics to back it up?:D
broncoitis
broncoitis
No Contest Pat! My welding is decent but I don't do it often enough. I will post up some pics later on forgot the camera at the garage. Go easy on me when I do! ;D
