NY-Bronco
Resident Dipstick
Im seriously diggin your dash layout. I still cant believe how much you have managed to cram in that space. Which AC controls are you going with?
I've been following, looking great.. One thing I'd reccomend giving some thought though.. I'm not sure about the heater control valve you've got. But, I've seen factory ones leak.. Might want to see if anyone has seen the type you have leak, or maybe rethink where you put it.. If your not going with carpet, I guess it wont matter much, but I'd hate to have coolant leaking in the truck after a nice rebuild..
HGM,
Thanks for the advice on the Heater Control Valve. Called up the place that I have dealt with: SachseRodShop and they said that they have never seen one leak that they know of from the valve. Hopefully they are correct but I am gonna find out. LOL! ;D
Not gonna go with carpet on the interior so even if something should go wrong, shouldn't be too bad to clean it up.
Thanks for takin a look guys! Glad that you like the dash so far. ;D Basically 10lbs of stuff in a 5lb area under there. However, believe it or not it isn't too tight.
Gonna be running the Vintage Air Horizontal Gen IV controls Herman. ;D Expensive but they take up the least amount of space. Actually, everything about the Gen IV system is expensive. LOL! :-[
Anyway, got some more crap done over the past couple of days! Was able to get the Lower Intake along with the timing cover and water pump mounted.
Also drilled and tapped the ACT Hole in the intake. Not completely pleased with how it came out. This is one of the many times that an extra set of hands woulda been nice! LOL. It is a little crooked but should be ok I hope.
Starting to look like an engine again! I think that the tall valve covers may be another casualty of the EFI swap. Gonna be close but I have a hunch they are gonna get in the way. Heck, gonna have to get another bronco to build and use all these parts on if I can't sell them. ;D
Shamu,
Hoping to take a trip out there maybe this summer to see some of the guys and gals. We will have to get together if it happens for sure. Definitely will stop by and see Jim if I can make it happen. ;D
Herman,
Yeah, gonna be using the explorer upper intake and I was looking it over tonight and guesstimating the clearance. %) Gonna be close for sure. Yeah, I hope that the ACT works out because it isn't terribly off but having somebody to hold the manifold steady would have allowed me to concentrate a bit more on the the angle of the bit and keeping it square and all. Either way I will see tomorrow if it is ok when I put the fuel rail and injectors in there.
We have to get together one of these days. I would love to see firsthand all the work you have done to your truck. Looks good for sure and I need a cheat sheet to look at. LOL! ;D
How about this weekend?
