Project Springtime or Busted!!!
broncoitis
broncoitis
My Luck!
I will tell you what, I am officially snakebitten! The funny thing is that it never fails me.
So here is the latest and geatest! So im in the process of building the new tank and im not sure of the exact location of the fill neck coming off the stock tank. Hmmmm???? Ok, let me call one of the vendors and ask them so that I don't have to go home and measure. Granted, it doesn't have to be a perfect measurement just close! So I give said vendor a call and ask, I have a simple request, "Can you tell me the measurement from the front of the stock tank to the front edge of the filler neck going into the tank?" He says they don't have any stock tanks, just the aftermarket 23 gal versions. I say, should be close enough and he say OK, lemme go measure. Comes back to me with a measurement of 7 inches to the front edge of the filler neck coming off their tank.
Only problem is that the leading edge of the filler neck is actually about 9 inches from the front of the tank. I called back said vendor to get a measurement from somebody else and they came back with 8.5 inches which is very different from 7 inches. Apparently the 7 inches came from the leading edge of the first vent tube! "HOW DO YOU CONFUSE A VENT TUBE AND A FILLER NECK on the GAS TANK!!!!!!":eek::mad:?:?
Tell me this kinda stuff happens to you as well????
broncoitis
broncoitis
How about this? I'm assuming that the tank width is almost equal to the inside frame width. I would try welding on a couple of brackets like these and then run a couple of j bolts to the frame pulling it up secure. The only thing I can see you having to watch out for is crushing the plumbing on top of the tank on the bed of the Bronco. Although you could handle that by welding a few "bump stops" on top that are just taller than your plumbing. I don't know man, just a thought. Maybe it will kick start your creative mind.
Keith,
That is a good idea with the J bolts! Something I will consider for sure! Actually, I was thinking of welding these brackets to the sides of the tank and bolting the brackets to the bottom of the frame by drilling and tapping some holes! Just not sure about the stress from any frame flex that would be tranmitted directly to the tank. Otherwise I think that would work!
Im also gonna make up some brackets to support the back of the tank if needed.
broncoitis
broncoitis
Gas Tank!
looking good Rob.
Thanks Jason! I'm givin it my best! ;D
Got some more work done on the tank today after work. Only got to work on things for a couple of hours but definitely made some progress! I removed that old filler tube which I installed way too far forward due to some misinformation. :( I was also able to get the tank mounts welded to the left side of the tank.
I think that it is gonna be really solid and im happy with how they came out.
Tomorrow morning I will weld the mounts on the right side of the tank and reinstall the filler neck and the vent tube! Hopefully I can get the tank washed out and painted before I have to head out for work. :cool:
broncoitis
broncoitis
Good job. Like the bracket idea.
You know what Keith, I think that it is gonna work out good. Should be really solid. Unfortunately I was gonna use the side mounts similar to Pat's but the place that has them flooded and I honestly don't wanna wait to get this tank finished and installed. Hopefully it doesn't bite me on the ARSE.
Not happy about having to move the filler back, but I think the patch came out OK and you really wont even notice it once the tank is mounted! ;D
Hey I just checked out your build and really nice job your doing on Pistola and a great story as well. Like they say out there, "Get R Done!!!!" ;D
broncoitis
broncoitis
Well, today is another day and hopefully it brings some good progress on the tank today! Hopefully I will get the rest of the brackets in place and also be able to redo the filler neck and vent tube before heading to work. ;D
backpain
So, the BCB tank skid plate is a pretty good piece. Fairly stout. Either that or similar tied into your rear frame rails and a good plate bumper would be fun (not really, but would be nice to have)
broncoitis
broncoitis
Yeah! I will probably end up making a skid plate in the future but for now won't be necessary! The bumpers on the front and rear are a whole different story. I am gonna either build my own bumpers or buy the old school bumpers from Protofab! :)
broncoitis
broncoitis
Tank Mounted! Almost Done!
Well, got some more done today! Finished welding the mounts to the side of the tank and I was also able to get the Filler Welded back in place and the Vent tube for the filler welded in place.
The tank is basically done! All that is left to do is pressure test it, clean the inside as best I can, coat the inside of the tank with the POR 15 tank sealer and paint the exterior of the tank. The only other obstacle is to wire it up and test the pump! ;D
Rox Crusher
Broncoitis - I don't know if I should be pissed or thankful that I ran into your post which I just read in it's entirety.
I am starting my EFI conversion soon and planning to install A/C at the same time. Like you, I don't care to do things half-arsed.
So it looks like I will follow your lead and change the cowl, etc.
A couple of questions for you:
- Did you consider the BC Broncos A/C kit and if so, what deterred you ?
- You didn't happen to make an extra cross over tube did you ?
;D
At any rate, your work is very impressive and your rig is turning out great.
THANKS (I think) FOR THE INSPIRATION !
broncoitis
broncoitis
;D
Rox Crusher,
If you haven't wasted any money on the aluminum radiator yet, I highly advise going with the EFI radiator! You can use the original one but going with the Newer EFI radiator would make life SOOOO much easier. If money wasn't an issue I woulda switched.
Considered the BC kit but decided to go with the Gen IV because I really like how it sits under the dash! The vents are also more centered in the middle of the Dash and the outputs for the vents are on the sides and not the top. As a result of this, you can tuck the unit up a bit higher than the BC setup! In a nutshell, I am stubborn sometimes and I was just determined to make it all fit! ;D My preference but the BC kit also works great. I do warn though that if you choose the GEN IV there is currently no kit available to install it in the Bronco! You will have to figure it out but it isn't that hard! The most difficult part for me was the stupid explorer compressor. If not for that woulda been easier!
Backpain, More Power!!!! Arrrr......Arrrrrrr..........Arrrrrrrrrrr!!!
broncoitis
broncoitis
What was the issue with the Explorer compressor ?
My 5.0L is from a 98 Explorer.
The explorer compressor uses a mounting block for the high ans low pressure sides! The Sanden compressor is easier to use I think with how the ports come off the back of it. In fact, I think that BC Broncos has a bracket to mount a sanden compressor on the explorer brackets. Otherwise check out Doc's Blocks. They have some mounting blocks that would have made my life alot easier. The explorer compressor is fine otherwise. That is what I used! Not tryin to hate on the explorer compressor. ;D
stupidboy
My wifes porn star.
Morrisdale Pa.
I'm just wondering, and I think when it comes time on mine that I will investigate it more, but what if on that block that the explorer pump uses, the tubing is cut off and aluminum weld on an fittings get put in their place. Something to think about if your going to use that pump.
broncoitis
broncoitis
Actually Pat, those fittings on the existing block coming off of the explorer compressor are brazed on so if you have an acetelyne torch you can heat up the block and the existing lines will come out pretty easily. At that point you can fab up lines that work around what you have in the engine compartment and braze them into place! Thats what I did and what was a royal PITA! Im really happy with how they came out but it was definitely some trial and error to get it just how I wanted!
If research it you can get all the parts to fab up the lines from a good A/C shop! Your gonna need the High and Low side pressure charge ports, a #8 and #10 male fittings to attach the lines to and the proper size tubing! ;D
