project tetanus build thread.
sprdv1
REBEL
yeah I still have quite a ways to go to get there, but I am making progress. the wiring is always my least favorite part. unfortunately I am a bit worried right now. I have a car show here in my small town on the 26th of september. I was hoping to be able to take the bronco to it this year. I ordered some seats from Toms bronco parts and with all the fires and stuff going on out there, I am afraid they won't get here in time. Hopefully they get things under control out there soon, and no more loss of life and property. My daughters new mother and father in law live right out near there as well. very scary times.
Good luck brother.. Yeah this year has been SH*T for sure Uggh
mustanggarage
mustanggarage
after I finished all the wiring, I installed the fan and shroud, I had filled the radiator a couple days ago. I spun up the oil pump before I dropped the distributor in. set up the msd box, and went through the initial setup on the fitech. I followed all the directions in the quick start guide. cycled the fuel pump on about 3 times. checked for leaks. no fuel leaks. so I cranked it... it cranked and cranked but wouldn't start. it smelled strongly of gas. I scratched my head for a bit then realized I forgot to take the stupid caps off the throttle bodies lol so I pulled them off, put the breather back on, and it fired right up, and promptly died. I tried several times to get it to keep running with no luck. I checked my electrical connections, everything was good. then I went back through my initial setup and saw that my pwm/fcc was set at 0 so I changed that to 40, and voila.
https://youtu.be/ZoZfK7stVFE
I am pumped. this is the last major hurdle, I still have a bunch of little stuff that will take a while, but it is really just little stuff now. unfortunately I just found out the car show I was hoping to take it to at the end of the month was just cancelled, so crap. I'm gonna be all dressed up with no place to go.
sprdv1
REBEL
I'm sure some more shows will pop up.. Keep pushing :)
mustanggarage
mustanggarage
got the billet turn signal pads today and installed them. I had to do some massaging on one of them, the other fit perfect. I also put my bumpers on and bolted the coil to the firewall and cleaned up the wiring a bit.
tomorrow, I think I will start putting the windows in the doors and mounting the mirrors. for some reason I am dreading that job
mustanggarage
mustanggarage
since the seats I ordered from Toms Broncos are on back order and won't be until November I decided to get some procar seats from wild horses they were in stock and should be here in a couple days. in the mean time I took an old foxbody mustang seat and sat it in place so I could position my side mirrors and bend my shifter handle to fit where I like it better, I am going to powder coat it in a day or so. I got the mirrors installed and did some work on the door handles to make them work a little easier. then I installed my one piece windows and door limit straps.
I like the way the inner fenders look on the bronco so I didn't want to put anything on them like the msd box or coil so I decided to do it like this.
in the mean time, a piece in my clutch linkage broke. one of the few original pieces I kept from the old bronco so I had to order a replacement. I plan to work on getting the tie rod and drag link on tonight and do a quick and dirty tape measure alignment. I don't want to ask my wife to help me bleed the brakes till my new seats get here. but I should hopefully be ready for a test drive soon.
mustanggarage
mustanggarage
Toms bronco parts premium seats that I wanted are on back order. so I went with these procar elite seats from wild horses. I fixed the clutch linkage, installed the rear driveshaft. I have to do some re arranging for the front driveshaft. I bent, and powdercoated the nv3550 stock shifter to suit my liking a bit better and I replaced the shift knob with a hurst cue ball shifter that I like better than the stock one. I also did some adjusting on the dana 20 twin stick shifters and had to modify the floor a bit more. then I got the boot in place. I will try to get some better pictures tonight. my bronco hut door panels are back ordered, but the interior is about together. I have not decided whether to put the power window kit in or not. but now maybe I can get the brakes bled.
mustanggarage
mustanggarage
My wife helped me bleed the brakes, and adjust the clutch linkage. then I backed it out of the garage under its own power for the first time. I let it warm up to operating temp, and kept an eye on the gauges. I still need to program the gas gauge, and for some reason the tachometer isn't working. but the oil pressure and temp gauge are working fine, the fitech has a tach reading so that isn't really an issue right now, and I only put about 3.5 galllons of gas in it, so I knew it was pretty low. since it seemed to be running fine and I saw no major problems I decided it was time to take it for the first test drive. I drove it down to the gas station, filled the tank with 91 octane at about 8:30 tonight. got my first thumbs up, and drove it home. it needs to be driven a bit more so the computer can learn, and I think I need to back the timing off a bit, the left turn signal stayed on whenever the lights were on, so I have that wired wrong somehow, but everything else seemed to work fine. I drove it home, noticed I still have a small oil leak from the oil pressure sending unit. I think I am going to have to take that off and put some more thread sealer on it and see if I can get that stopped.
I still have a lot of small things to do, but another major milestone in the bag. if they hadn't cancelled my car show that was scheduled for this weekend, I would have been ready.
jmhend
Looks amazing. Great job!!!! Now button up the little stuff and enjoy the heck out of it.
Sent from my SM-N960U using Tapatalk
mustanggarage
mustanggarage
will do. I am going to try to do some tuning on it tonight. I still haven't run the vacuum line to the brake booster so I was using manual brakes last night. and of course I have no seat belts since I have no roll bar. but I did tell my wife that for christmas a roll bar would be a great present lol. I plan to put a few miles on it before the first snow falls, then I will have to tuck it away till spring. but there are still plenty of details to hash out over the winter.
mustanggarage
mustanggarage
had a couple minor setbacks. my own fault of course. but I am back on the project now. I went ahead and installed the door panels and marine grade speakers. with the billet door cups and window cranks. I decided to nix the idea of trying to make the one piece windows powered. so they will just have to suffice in manual mode lol.
I also put in a center console
with the way the dash in these broncos are made and the way the steering wheel comes through there the steering wheel works best in this configuration. it may drive me crazy, but I am going to run it this way for awhile.
I got to drive it a little today and let the fitech learn. it still has a way to go, and I am still trying to tweak it to make it run right. I will get it, but it is a work in progress yet. I also need to set the brake bias with the adjustable proportioning valve, but first I need to get it aligned. that is scheduled for tomorrow. once it is aligned I can drive it without worrying too much. then after I drive it a bit I will put it up on the lift and check all the bolts and fasteners again, make sure everything is tight. I have a bit of an oil leak underneath, I am afraid I may have a rear main seal leaking. probably damaged it putting the trans in, smh. but I did get the pcv system hooked up today so I will drive it abit and see what happens there. I decided to sell my 89 convertible to pay for some bills and so I ordered some more bronco parts. I ordered the roll bar and besttop soft top as well as a bunch of small parts. things are coming together. I will be ready for next car show season.
Howard2x4x4
Absolutely drop-dead gorgeous! Kudos, applause, standing ovation, etc.
sprdv1
REBEL
I would expect quite the bit of awards once you do...
Looks awesome
mustanggarage
mustanggarage
time for an update. I struggled with the fitech for a very brief period of time, but I could not get it to run right and the instructions and online support were no help. ever since I ordered the fitech I have been reading and studying stuff on line and in this forum and I decided I really wanted to go with the holley system for a number of reasons, and since I sold my 89 convertible I had the cash so I bought the holley sniper system the system seemed so much easier to work with. I swapped it over in about a day. it was a very easy swap I just had to add a fuel pressure regulator and replumb the hoses a bit, and the wiring was easy since it was basically the same as the fitech so I just re used the same wires. I had to majorly retard the timeing, I am sure that is part of the reason the fitech would not run right but again terrible instructions. Now it runs 100% better. I have a guy who tuned my convertible who helped me figure out a couple adjustments. I need to re plumb my pcv valve since the sniper only has one port for the brake booster, but there is a port in the intake manifold I can pull out once I get the proper hose barb on monday. it isn't quite there yet. but it is running a lot better. It just scoots when you mash the pedal. but its a bit chilly driving with no top lol. I am still waiting on my roll bar I ordered from toms bronco parts. once I get that in I can put the top on it. in the mean time I put the top front adapter plate that is necessary for both the soft top and the bikini top on, and it also covers the windshield wiper cover so I could install it. I also finished up the speaker install and found that the one piece windows made the door panels not fit properly so I had to modify them. I have discovered a power steering fluid leak which I am struggling to stop and a rear main seal leak which will have to be addressed at some point. it is a one piece rear main so I will have to drop the transmission to do it, gggrrrrrrrrr. but the truck is running pretty well and it gets a lot of positive looks when I am out, either that or they just think I am nuts driving around with no top when it is 48 degrees outside lol. anyway I am making slow progress. next things are to continue to tune the engine, I want to raise the center console up a bit so I can move it forward so I am going to get some square tubing and make a base to lift it slightly. I also still need to finish the emergency brake cables.
here are a few recent pictures.
gratuitous shot of ozzy
the sniper handheld will not be staying there permanently. I ordered a speedhut fuel pressure gauge to match my other gauges and it will be going there eventually. the handheld will be mounted in the glove box with a quick release mounting bracket that should make it look good and be functional when I no longer need it on a regular basis.
mustanggarage
mustanggarage
after a major SNAFU the Bronco is back up and running. It's an embarrassing story, but the short version is that the Blueprint engines 408 stroker I ordered from Summit had been replaced with an upgraded version. it comes with about 50 more hp, which is awesome, but it also is internally balanced, and the engine I thought I bought was 28 oz externally balanced. so no surprise there was a nasty vibration, and that explains the rear main seal leak. When I was sending in my tech sheet to Adam Nick Langen from mad scientist tuning to help me tune the Sniper system I discovered my mistake. fortunately I had barely run the engine, so no major damage was done I don't believe, anyway I swapped out the balancer and flywheel and a few other minor things and with the help of my awesome neighbor) I have it all back together. and running. it is much better. I still have an occasional backfire when decelerating, but for my first test drive tonight it was pretty good. I will drive it some more tomorrow to let the fitech learn, then I will make a data log and send it over to Mad Science tuning to get the tune dialed in. on another note, I called toms bronco parts to check on my roll bar, and it is a good thing I did. apparently someone had pulled the order and billed me but the order was never completed. it should be here next week. just in time. I wasn't ready for it before now anyway.
I needed to use several of My Dad's tools this week to get the flywheel swapped. He's been gone a year now, and still helping me. and I still said "oops sorry Dad" when I found I put one of his tools in the wrong spot, lol he was always very particular about his tools, and his toolbox is still almost exactly the way it was the last time he was here. I have always been a bit hesitant to use his tools, I usually grab my own first, but he has some specialty tools that really help, and he had some large ring connectors in his electrical drawer that saved me a trip to the parts store. Thanks Dad.
now to clean up this mess of a shop and prepare for the next phase of Bronco resurrection
mustanggarage
mustanggarage
some pictures from my daddy daughter date. first cruise that wasn't a test drive.
