Ned
I think I got some bad advice to simply run breathers on both sides. Any thoughts, pictures, advice. As far as I can tell in my search in this fourum most people are pro PCV set up for various reasons. My question is what is the best way to set up the system, I have read to put a breather on one side and a PCV valve set up going into the base of the carb. I have a holly 650 and an aftermarket aircleaner. Keep in mind the air cleaner does not have a set up on the botom of it for another tube as the stock one did. I am assuming that was the tube from the drivers side, but honestly I cant remember.
I could run the old air cleaner but I would have to install a spacer on the carb in order to clear the curent HEI Dist set up, and I really dont want to get into that right now since the studs on the Edelbrock intake are not that long and would have to be replaced to fit both the carb and spacer.
