Proportioning valve for 76-77
JWMcCrary
OK, maybe a dumb a question. The wiring for the warning light, does it serve any other function besides turning on the light? I didn't put that light back in the dash so it's not connected. We can't get but a trickle of fluid to the rear brakes, everything is new except the proportioning valve, all lines are open. Seems the valve should be the problem. Front brakes are fine, issue is with the rear. All stock parts for a 76, disc front, drum rear. When I say everything is new, that's everything with the exception of the proportioning valve.
Apogee
Tangent, OR
The pressure imbalance switch only powers the brake warning light on the dash...that's it. As for the rear brakes, make sure your MC is fully bench bleed (plug outlet ports and confirm it hydraulically locks and doesn't sink over time with steady pressure) and then pull the pin on the combi-valve to bleed the rears.
JWMcCrary
JWMcCrary
So where exactly is that pin? Never had to do that before but never had everything replaced dry and started from scratch.
