ps box and hydroboost fitting sizes?
Mark
Bronco Klutz
NW Indiana
eds66bronco,
did you complete this setup?
I'm gathering parts for my Hydroboost install and have the mid 90's Astro H-boost and Napa power steering pump
Do you have any photos how this turned out for you?
eds66bronco
eds66bronco
Essex, Vermont
Mark Troy said:
eds66bronco,
funny you should ask, i just snapped some pics the other night.
first shot shows the h-boost and bracket (red thing on fire wall) that i made to angle it away from the upper intake.
second shot is a top view that shows the plumbing. the black metal hardlines from the box output goes to the a tranny cooler i mounted in front of the lower radiator in picture 3 and then to the second return i welded onto the pump.
the last shot is how i extended the pushrod. i cut the rod and welded a coupler nut onto the rod that goes into the h-boost. i put a wet rag around the bottom of the rod where it went into the unit to keep it from melting anything inside. then i took the pushrod from the crown vic, cut it down and treaded it to fit the coupler nut. i was concerned about the angle of entry into the unit but it travels all the way in without hitting the side so i think it's ok
toddz69
Looks like you did a very nice job.
Todd Z.
eds66bronco
eds66bronco
Essex, Vermont
Todd Z.
thanks to you and all the others thet helped me out. now it's time to tidy up all that wiring mess. doesn't look that bad till you see it in a picture %)
bigmuddy
Marthasville Missouri
hydroboost
Hey are any of you running the boost unit and retaining the stock column shifter for the C-4? It appears that when i trial fit the astroboost unit that if I install it in the stock location it will hit the shift linkage to the C-4? Just wondering if I move it up the firewall how much angle I can get before causing a problem?
Madgyver
Bronco Madman
You can angle it to the right towards the driver side this much.
I never completed the article yet on how I did this so email me if you want details......
eds66bronco
eds66bronco
Essex, Vermont
i have the auto culumn in mine but i'm running a np435 so i didn't care about the linkage. it would not work the way i have it, as the linkage will hit the booster. You may need to get a vacuum booster bracket. if you move it up, you could also make a bracket that could correct the angle.
broncow72
Village Idiot
Spring,TX.
I put mine in the clutch pedal location. Theis gives me gobs of room between the boos assy. and column and motor. I'd post a pic but I'm a cheap bastard who hasn't gotten off his fat arse and contributed yet.
Mark
Bronco Klutz
NW Indiana
Madgyver, please email me these details.
Thanks,
Mark
mtreu@csinet.net
TOFIC
Bronco Wrencher and Fixer
Redcliff Alberta
Mine originally was just that, auto and standard HBoost. Inverted the unit and everything worked fine. Little "snug" but it did work.
I have since changed mine, added the "MONSTER' brake pedal and shifted the unit over to the clutch location. Had too, the 351 mandated this. Not hard to do getting the right brake pedal makes it easy.
Got pictures of the old and new install let me know what you want and I will send you a few pics.
TOFIC
Mark
Bronco Klutz
NW Indiana
TOFIC
Please post those pics. before and after
Thanks!
TOFIC
Redcliff Alberta
Thanks!
Mark Troy
If i posted all the pictures I have JON would shoot me for hogging all the bandwidth for a long time send me your email address and I will send you some.
TOFIC
Madgyver
Bronco Madman
Thanks,
Mark
mtreu@csinet.net
Mark, As soon as I get a chance to put everything together I'll send it. For the moment you can pull pics from these threads. The 3rd link has pictures of the bell crank on the page 2.
http://classicbroncos.com/forums/showthread.php?t=66303&highlight=astro+hydroboost
http://classicbroncos.com/forums/showthread.php?t=59729&highlight=astro+hydroboost
http://classicbroncos.com/forums/showthread.php?t=60141&page=1&pp=15&highlight=astro+hydroboost
