Mark Troy said:
eds66bronco,
did you complete this setup?
I'm gathering parts for my Hydroboost install and have the mid 90's Astro H-boost and Napa power steering pump
Do you have any photos how this turned out for you?
funny you should ask, i just snapped some pics the other night.
first shot shows the h-boost and bracket (red thing on fire wall) that i made to angle it away from the upper intake.
second shot is a top view that shows the plumbing. the black metal hardlines from the box output goes to the a tranny cooler i mounted in front of the lower radiator in picture 3 and then to the second return i welded onto the pump.
the last shot is how i extended the pushrod. i cut the rod and welded a coupler nut onto the rod that goes into the h-boost. i put a wet rag around the bottom of the rod where it went into the unit to keep it from melting anything inside. then i took the pushrod from the crown vic, cut it down and treaded it to fit the coupler nut. i was concerned about the angle of entry into the unit but it travels all the way in without hitting the side so i think it's ok
