PS box "flexing," is this possable
reamer
Hi all
On my '76, It occasionally wants to go over here or over there while going down the road.
everything seems tight, but I did notice when I rotate the wheel back and forth I can actually see the top of the box flexing back and forth about 1/4".
Where the box blots to the frame is tight. Is this possable, the box actually flexing (33" x 10.5" tires) or does somthing have to be loose/cracked/stressed? I can't get a really good look to see if the whole frame horn is wiggling with the box.
Suggestions?
reamer
rhinobuggie
Hi , You will get some movement from the box , but not that much . Check the frame around the box , it may be cracked ! Clean the frame , then have someone turn the wheel back and forth with the motor off and look at that the area around the box . Also look into the frame where the bolts for the box are , does it look like the frame sides are being bent in ? I have seen this when the bolts are over torqued . A thick wall pipe can be put in , the width of the unbent frame and the bolts go through it . If you have a locker or are planning the get one down the road I would get this set up http://westtexasoffroad.homestead.com/hydrosteering.html I have 37 inch rockers and a locker and I can turn the steering wheel with one finger at an idle .
86caprirs
Chestermere, Alberta
Mine flexes alot too. I can see it where the bolts are. I think I may get a piece of channel and drill the three holes and weld it to the frame. Then longer bolts and it should be better.I hope.
nickm
South Houston
I found a brace one time for the seal area around the sector shaft, but I cant remember who made it. I assume its to help eliminate this. I have the same frame flex.
The brace was about $150
rhinobuggie
You have to look at the box side of the frame too . I have seen it crack the frame around the outside edge of the box .
nickm
South Houston
Here it is..
http://www.wildhorses4x4.com/product/Rebuilt_F100_Power_Steering_Box/Power_Steering_Kits
rhinobuggie
I put the ram asst on my truck , and was kick'n myself for waiting so long to do it . It was like going from non P S to having PS The down side of doing it , now the wife wants the drive
eb66to77
Bronc'Ownly
NOVA
Duff made a saddle for the sector shaft that went around the housing. Not sure if they still make it.
