PS Upgrade time
NC-Fordguy
Bethel/Greenville NC
I beleive the saginaw PS pump is slowly dying. Squeals from time to time, is jerky at times while turning through a corner and is nearly impossible to turn the tires when in a rut or cought up in some rocks. Currently running 33in tires and I am planning on running 37's after I do a re-gear. The steering box is a F-150 box
I've been looking at the Wild horses extreme duty PS pump. Any of you all running this set-up?
Thoughts?
Ed
Pokey71
right now i have a 2WD box and a brand spanking new WH pump with 33's.
pump works great and never heard a sound from it
74BroncoCO
I pulled a saginaw setup off a early 90's astro Van with remote Reservoir. I decided to just run it and see what happened. It's been flawless for two runs so far without anything more than a clean-up. Plus you gain the extra fluid capacity. If it's dead, use it as core on a reman. Just something to think about...
Pokey71 - I just had to laugh at your sig. Yeah, I understand!
J.D.
