PSC hydraulic Ram Assist Install
JohnJohn
JohnJohn
Richmond
I am waiting for the steel NPT fittings to arrive.
I was able to get the end cap in with a new O-ring but the retaining ring is a pain to get in. I need to get some small screw drivers and take my time. I also think I may need to use a punch to seat part of the ring as I go. I makes a very tight fit where the ring needs to fit in. I did my best to clean that area out and sand it down before I installed the cap.
I am also a bit concerned with the depth of my 1/4" NPT tapping job on the top cover. I drilled the hole with a 7/16" bit like you are supposed to but the NPT tap got to a point where it was very hard to turn it any further. I have complete threads in the hole but as you can see in my pic the fitting is roughly half way into the tick aluminum cap.
I was using a small 8MM wrench to tap the cap with a 1/4" NPT tap and some PB blast to lube it. I wonder if I should use a 12 point socket on the end of the tap and a longer 3/8" ratchet to try and get the tap deeper to widen the top taper end of the hole.
Any thoughts?
I have tapped many holes in my life but only a couple NPT tapered ones. I am afraid I will break the tap off in the hole if I push it to hard.
JohnJohn
JohnJohn
Richmond
I made progress over the weekend. I installed steel NPT fittings vs. the aluminum ones and made my high pressure hoses.
Every Bronco is different but mine has a 2" body lift and the previous owner installed the front sheet metal without a tape measure so its all over the place.
I had to cut part of the lower radiator mount to clear the front hose. On a normal bronco with a 2" lift it may work better with a 45 degree fitting so the hose can run out in front of the grill then back down.
I will be installing a cooler tomorrow then filling it up and starting the bleeding process.
bigjhoov
nobody
I was wondering how you were going to get a hose on that front port. Most of the time the nose of the both is buried in the core support.
JohnJohn
JohnJohn
Richmond
It's done and working now. It was a much larger project than I thought it would be but they all seem to go that way.
Scrapper_MV
Question for the PS gurus. I have a PSC pump and hydroboost brakes. The pump is struggling to keep up with my 37" tires, and gets very hot. Would adding a ram assist put more strain on the pump or less? I also would like to go to an Explorer serpentine belt, but I'm not sure that an Explorer style PS pump would last very long. Sorry for the high jack.
JohnJohn
JohnJohn
Richmond
You could put a big cooler to help but a ram assist will help relieve your box as well as your pump.
I am running very heavy Humvee wheels with 37's and I lost a Saginaw pump with no cooler in a few hours of wheeling.
It could have been a week pump but it worked fine just driving around.
bigjhoov
nobody
JohnJohn, that ram mount on the axle side really should be in double shear. You might want to consider replacing the single stud with a set of tabs at some point. I bet you bend that stud.
JohnJohn
JohnJohn
Richmond
I may make a second bracket to give me a double shear on the axel side.
According to PSC I should not mount the links on opisite plains.
When I mocked it up with the hemis on opisite plains in a double shear the hemi was binding.
I was hoping the stud mount would work after seeing so many installs with these type of students clamps on the tie rod.
JohnJohn
JohnJohn
Richmond
I was also looking at the track bar stud mount on the axel and thinking it must take a beating and hold up but it's not taking hydraulic force.
I will weld something and add it in. It can only help.
bigjhoov
nobody
Yeah, I guess that's true. I forgot about those clamp mounts, I'm used to the tabs.
