On the schematic, the only purple one from the ign switch is going to the brake warning switch.
There are clips that hold the tail light harness up? Learn something new everyday, lol. Just the other day I realized there's suppose to be a spring on my tire carrier latch.
The purple wire comes from the ignition switch, through the firewall harness, through the switch, back through the firewall and to the lamp.
It should meet up at the Brake Warning Lamp with a Red/Yellow wire.
Are you sure this isn't the connector OFF of the ignition switch?
Look on the side of your ignition switch. If it's got a male blade connector with no wire on it, the Purple one in your hand should be there.
In fact, it probably should be there anyway, whether it's got a stripe or not, because it's got the correct connector for that circuit.
Did your '70 come with a charcoal canister on the frame and a condensing tank behind the driver originally? If it did, then those missing clips were for the metal tubing from the vent lines to the main tank.
I've occasionally seen wires clipped there, but more often than not, on mid-'70 and later models it was for the evap tubing.
Is this for the '70 or are you working on another one? If the '70 what month was yours built in?
Could be, just seemed odd it is such a large wire and darker purple than
the wires going to brake warning lamp connector. I have Stang HB and
was thiking of adapting light to the MC level switch (and may try to
install a switch on the emerg brake pedal mechanism too).
Can't see the side, can't see it at all really, so I pulled out my lucky broken mirror, which side am I looking for.
My 70 didn't have any emission stuff on it when I got it,
but it was far from a factory unmolested rig. Not sure what
month. But anyway, are those clips avail, they work really
well for that wiring harness. If not new, I'll start digging
around for used one's.
In the indent of your switch connector you can see the male spade. In your picture it's to the upper left part of the ignition switch connector.
The other answer is that wire is for the positive side of light and the connector in engine compartment is for the ground side.
Not sure why the positive side of circuit needed to be so much larger.
The other side of the circuit is the 12v power, and both the 2-wire switch on the H-block under the hood AND the tab on the ignition switch are paths to ground.
The plastic switch on the H-block is simply a pass-through when it's open, and when it's closed it grounds to the frame through the H-block.
The ignition switch's connector is called the "proof-out" that many ignition switches had back then. It's just a test-ground, so to speak, that in this case is utilized for the brake warning lamp circuit in a Bronco and other things on other vehicles. Or nothing at all on most other vehicles.
