SaddleUp
Right now they are all hanging loose under the body and if I play with them a bit I can get one or two to shift. (Reasonably the only way to shift it right now is to climb underneath and use a big wrench) The bung on the side of the transmission I used to connect them is hanging loose with them. (No longer attached to the tranny) I would like to move it anywhere that will allow me to build a console that runs from the seat all of the way to the top of the dash. Not too easy with 4 shifters in the way. One of them I can incorporate into the console by removing the apron and adjusting the brackets underneath but that isn't going to work for the transfer cases. It really doesn't look like it will be too complicated to do. The hardest part will be building a bracket or brackets underneath at the case. The cable strength doesn't worry me and the pressure needed to shift the cases doesn't worry me.Broncobowsher said:Personally I don't consider the cables to be very praticle.They are already in a pretty good location, where are you trying to move the shifter to that would be so different that it would require cable shifting? I could see in a tube buggy maybe?
