Just an update. I think I have the wiring figured out. I was going to use the pigtail harness I got (73-76 F100) but the quality did not seem that great and the wires seemed a gauge or two smaller than my Centech harness. Also, the plug doesn't really lock in like a modern harness with a clip and such, so I am 90% sure I am just going to use 4 spade connectors with shrink wrap and it will be a better more waterproof seal anyway. and will pull out just as easily as the F100 plug (which sucks because I want it locked in to prevent it from pulling out. I may still figure that part out. Anyway, after sorting through a million blurry diagrams and wrong model year pictures online, I just decided to use multimeter and do continuity test on the terminals and I should have just started there. If any of my electrical terms are incorrect, I won't be insulted if you correct me. I am an amateur and try to remember the terms I have heard along the way from others.
I made this simple diagram of the actual back of the switch. For me it is only 4 wires and to be honest it is only really 3, let me explain, the ACC2 position (what I call turning key to the left of OFF) should only probably have the heater circuit it on it. I have completely deleted everything related to the heater/fan system in my truck. The whole circuit does not exist nor does the hardware, but that is where you would wire it. Instead, I have the ACC2 circuit and the ACC1/RUN (what I call the first notch over between OFF and START) both wired into the same circuits on fuse panel, which is fine for me, but maybe not you (aftermarket self-made fuse panel) so for my simple truck, everything works on both key positions.
There are 2 terminals that I believe are called PROVE OUT, I am not using these because I do not have a Brake Warning Light or Brake Switch. I believe (someone chime in if I am incorrect) that this is where you attach those items. Apparently, some Fords (mustangs) used 2 terminals, and some used 1. I don't know personally.
I have a 1990s Centech harness, so for my diagram I used the color of wire for the arrows/words associated with that spade terminal if that helps anyone. As far as an OEM harness, I don't know the color wires you would have. I will update more when I get a little farther along.
