Quarter panel Side Exhaust??
RODRIG3911
Tucson
Hey guys! I've been getting vapor lock and it's my thought that it might be because my rear exit exhaust goes too close to my electric pump and tank..... That said it gives me a great excuse to try to make some kind of cool side exhaut like the one in the attached picture;D.
Does anyone have anything like this and can you please comment on how it works for you and what you used for a circle mount thingy on the quarter panel? Please post more pics :)
Broncmeister
I didn't run mine through the quarters, I ran them under the quarters with a tip that angled the exaust down at a 45.
patterdale
Do a search on on here for side exhaust or quarter panel exhaust. Depending on your configuration of top on top off or soft top. Pretty much anything but the stock exhaust exit can cause problems with fumes in the cab and or when riding slow on the trail with no top. best to read up on other's experience before spending the$$$$$
jasonb
Howard City, MI
Ford tried the side exit exhaust ahead of the right rear wheel on the 1997 pick-ups. They found out that the exhaust is very corrosive and destroyed the right rear wheels and center caps in a very short amount of time.. They came out with a TSB and had us put a muffler and tailpipe assembly on the exited in the normal place behind the right rear tire. Just a thought.
DonaldDouchebag
The fumes wiill choke you out. Don't do it if ou plan n driving with the windows open or top down.
RODRIG3911
RODRIG3911
Tucson
Thanks guys for all the ideas. I never really though about the fume issue %). The thing is that I have a really nice custome exhaust right now with long tube header duel flow mast 40's and rear exit, but I wanted to mount the electric fuel pump near the tank on the inside frame to prevent vapor lock and my exhaust system runs too close to the frame to make that happen.... That orange bronco exhaust looks sweet!!!
BroncoJAK
No problem with the fumes with my side exhaust as long as we're moving. Been stuck in a v-notch leaning on the exhaust side and it got pretty heavy. If you run rear exhaust the vacuum created behind the vehicle driving at speed can fill the cab with exhaust.
Rustytruck
My exhaust exits Between the leif spring and the frame and exits right in front of the rear tire between the tire and the flair. I have no fume issues in the truck with the top and doors off or with the soft top and doors on. I will tell you that people in the lanes next to me in traffic stop situations don't like it though. In all the exhaust positions I have had this has been the best for me.
Under the truck sucked, too much dust blown up and some fumes. Out the back was the worst for fumes. Out the back of the tires on the sides always got trail damage. I liked the set-up one guy was doing with 4x4 rock sliders doubling as exhaust ports I wonder how that finally turned out.
RODRIG3911
RODRIG3911
Tucson
That's what I might end up doing. the quarter panel thing would have looked super cool, but probably not a great idea. I'd love to see the rock slider exhaust your buddy's doing!!
jim3326
Appleturkey
I'm not quite there yet but mine will be exiting thru the slider. Have to get it put back together first%)
Jim W.
RODRIG3911
RODRIG3911
Tucson
Jim3326 that is super creative! That's one thing I like about our broncos.. we can be creative and do wild things to them and it's cool. Except for the stock lubers we all put our own custom touches to them and our personalites start to show in our Bronco. It's like art ;D
BoureeOne
Madisonville, La
Here is what I am going with. Shelby Cobra Roadster Side Pipes....
BoureeOne
Madisonville, La
Two things I am doing to try and prevent that. On the Shelbys they are literally mounted sitting on side of car. I plan on tucking them slightly under. Also, I am going to make a custom step that comes out above the pipes and then curves down. I thought using the step will help keep legs away from the pipes.
