Rollin
I have been doing some more reading and it looks like you can bolt up a
AOD tranny to a NP 205 case and don't need the adapter. So that would save a lot of money, but you have to change out the yoke. Will this still work if the tranny came out of a car not a 4x4. Then what about when you go to set up
the floor shifter for the tranny, or the 205 case, is there some changes that need to be done or is everything bolt in?
I'm getting ready to make the shift from a I6, 3 speed on tree, D20 case
the new set up is 93 EFI 302, AOD, transfer case?
The D20 needs to be rebuilt anyways and I thought this might be a good change if it might cost a little less.
Mark
Mark
