Question for Holley Terminator users
JWMcCrary
I'm using a Holley fuel pressure regulator that has the manifold vacuum connection. On my initial install I had this hooked up but was having some problems that later turned out to be fuel tank vent related. In the process of troubleshooting I plugged off the vacuum port and have left it that way. I've read conflicting information on whether you should or should not use it and had been convinced until recently not to use it. After studying further it seems the Terminator is in fact a system that you should use it because the injectors are below the throttle plates.
Just curious who else may be using it with the manifold vacuum and whether it's worth having to let the fuel table learn again to make the change.
snipes243
Huntersville, NC
I have mine hooked up, honestly seems to work better. Although I don't have any definitive data about it.
JWMcCrary
JWMcCrary
This confirms it for me. I copied this straight from the help section in Holley's version 4 software. This was not in the installation instructions that came with my system.
There is a vacuum line going to the fuel pressure regulator (for Multi-port and Terminator systems only, other TBI systems are not vacuum referenced to the intake manifold). This is needed to compensate for vacuum present in the intake manifold. Make sure you always use this vacuum line. When the engine is running and the vacuum line is hooked to the regulator, the pressure seen on the fuel pressure gauge will be lower depending on how much vacuum is present. 2 inches (Hg) of engine vacuum will lower the fuel pressure 1 psi. For example, 15 inches (Hg) of engine vacuum will lower the fuel pressure about 7 psi. This is normal.
KyddsPly
Sooooooooooo- hooked up or no?
