- Oct 11, 2007
- 405
So before I had broken both the explorer and power stroke pumps apart, both seemed to have some shaft end play. I transferred all the internals of the 6.0 into the explorer pump with a new gates seal kit and now shaft has zero end play and it is now somewhat harder to turn. I have torn the pump apart two different times to verify everything is in there correct verifying from multiple sources I have found and it looks to be correct. I
Can take the rear cover off the pump and the shaft will spin freely and the end play comes back.so the end cap and bushing seems to be the issue. The only difference is I had to reuse the 6.0 end cap in my explorer housing because i broke my explorer cap. Once I install the cap back on, the shaft gets tight again and zero end play.
So my question is, have you guys had this to happen after rebuilding the pump? Or is the 6.0 end cap different than the explorer one and maybe I need to grind a little off the end of the pump shaft to get some clearance there?
Any feedback is appreciated!
