norm02
- Feb 8, 2016
- 336
So I’m thinking about moving forward with a suspension lift earlier than I had anticipated due to my newly acquired Bronco Lean. My springs are the originals and I’m sure they’re sagging so I’m thinking it makes sense to just get the lift now and install it since it looks like I will have to have to take my front end apart anyway to fix the Bronco Lean. Check out the post I made regarding Bronco Lean if you’re wondering what started my new issue..
My future plans include new front and rear bumpers and they will probably Protofab Rock Solids and the rear will have the spare tire carrier, gas can, and cooler rack. That will easily add ~250lbs to the rear of the Bronco by the time the spare tire is mounted. I’d rather my Bronco sit slightly higher in the back or at least level than I would higher in the front and I’m thinking that due to the extra weight in the rear, it would make sense to buy 3.5” lift rear springs and a 2.5” front lift kit.
My first question is, should I get one inch taller rear springs or will my Bronco still sit higher in the back (with the added weight) if I just install a 2.5” kit? The kits I’m considering are the 2.5” Superflex from JBG or the Premium 2.5” kit from Wild Horses.
My second question is do I need to get a longer rear driveshaft if I end up going with 3.5” rear springs? More than likely the bumpers will happen after the lift is installed so I would drive it some before it has the extra weight added to the rear of the truck. Not sure if 3.5” rear springs will cause any drive line issues until the rear bumper is installed and the rear end squats back down.
