I like to ride without the top but don't always have six people to help put iy on and take it off and wondered if anyone had come up with a hoisting storage method or something like it?
Several different ways. The simplest I know is to get two tie down straps and 4 eye bolts. Run one strap under the front in the corner of the door opening and then up to an eye bolt in the garage ceiling on each side. One person normally can easily lift the end so you can lift it up a few inches and tighten the strap. Now run the other strap across about 18" from the back. Then work it up a few inches at a time at each end until it is off. Be sure to leave the liftgate closed when it is stored this way so the sides don't bow in. Some people take this a step further and use 2x4's under the top with 4 straps but I personally don't think it is necessary. My top has been hanging in my garage for about 1 1/2 years just using nylon rope and eye bolts. Just be sure the eye bolts are big enough to go into the studs.
If you have a Harbor Freight or Northern Tool near you you can get a hand crank trailer winch for cheap. You can get the pulleys and cable also cheap.
Mount the winch to the wall with some good lag bolts (into studs), screw in 1/4" j-hooks into overhead joists and hang pulleys on them. How you thread your cable is your choice. It can be daisychained but takes for ever to hoist up all the way or you can run the cables in parallel (4 lines to winch drum), it goes faster but might have trouble with cable bunching.
I used a pulley set up and and used my winch on the front of the bronco to put my top on and off with the press of a button ;D Just had to make sure things didn't hang up on the way......
