Hardtop Quick Release...?
TRSmith99
Oakland
Has anyone come up with a better design for securing/removing the hardop?
The standard design (as you all know) can be summarized as "screwed" - or maybe bolted in place is better. ; > There are bolts across the top of the windshield and several down each of the bedrails.
Has anyone retrofitted this to something more similar the Jeep hinged connectors?
Seems like it be a relatively easy retrofit to a Bronco hardtop...?
Thoughts? Pics?
T-
No Hay
My thought is those latches look bad.
Hex bolts aren't too bad, and I can have the top off in 20 minutes.
Putting it on, just a little longer.
AZ73
You can save some time by replacing the nuts with rivnuts, then use a shorter bolt
Whoaa
I agree that you, or anyone, could come up w/ a quick release system.
However the act of taking the top off, and then sitting it back on is the simple and easy part.
Putting a top back on, and making it align corrently and all of the seals to fit perfectly can and often times does take hours of labor, and has $ cost.
So even if you had quick release fasteners, that does nothing to address the issues of making the top fit properly.
.....>Additionally, often times these old Bronco's will splay open a little bit on the rear bed if you operate it much w/o a top.
......>And if you take the top on and off more than a few times you're asking for it to get tweaked, bent, or otherwise screwed up in some way.
matt w
I have taken my hard top along with the hard doors off and on for at least the past 7 seasons!
I use a hoist type system and this year was the 1st time I put/lowered it on to the truck by myself.
I don't know how anyone can put a hard top on or take it off in 20 mins with the needed weather seals as well as removing the riser if you as I do run a shader in the summertime. I have tube doors and also install my hard doors back on for the short winters we have in So. Cal.
Takes me AT LEAST 3 HOURS MINIMUM to totally complete the entire process of removing and replacing whether switching from winter to summer or vice versa.
I think a quick release system would be SaaWeeet! I have thought about it!
I was a machinist and in manufacturing for about 10 years. That style of latch makes sense to me BECAUSE you can adjust the tension on each individual latch.
I 100% like the "idea" and would pay for a decent well thought out option to nuts and bolts!!!;D;)
