Quick wiring question...
kaisermusic
Chehalis WA
Why does wire 26 have to be double grounded? In the pic it is running from the ground off the alternator to the body. It then runs a ground jumper to the volt reg. is this necessary?
jim3326
Appleturkey
It just makes the little electrons happier to know they have a clean road to travel. Sometimes the ground isn't that great between the body and any other piece of equipment. If the lap joints in the body start to rust then it interferes with the ground.
Jim W.
Viperwolf1
electron whisperer
Wire 26 gives the voltage regulator the same ground reference as the alternator. Important if you want them to work with each other and be located separately.
