Radiator hook up
HotWheels
Twilight Zone
I've got extra brackets if you need them. What r u trying to do with the radiator? Do want to move it or something?
md_lucky_13
Idaho
If you do somehow come up with a way not to use the brackets, you really need to make sure that you have some kind of bushing between your mounting system and the radiator.
If you have any metal to metal contact, you will probably wear a hole into the radiator very quickly, and spring a leak out in the boonies.
B
Boulderbronc
Longmont, CO
Skuzzlebutt said:
The brackets need to fit the radiator.
Whos rad are you using and why don't you want to their brackets?
Im using a 4 core from Bronco Graveyard and have new brackets. I also installed a newer 302 w/50 oz balance. Which I had to switch to a serp. set-up. I only have about 2 1/4" between pulley and radiator. I don't want to put in a electric fan, so I need more room.
VBH289
Colorado
Im not using the stock brackets with my WHS4C, I have a piece of angle iron on the bottom that bolts directly from the core support to the radiator on the bottom and then on the top I have two pieces of bent spring steel... way stronger then stock, if you want pics pm me... hope that helps
HotWheels
Twilight Zone
I grabbed some aftermarket hangers, took the new upper, inverted them behind the lowers and stiffened the whole support right up! :)
