Radiator Options - Reverse? 351C help
GrillMaster
My top tube exits the passanger side and the bottom tube exits the driver side.
I believe this is the reverse of a usual bronco radiator. What are my best options for good replacement? I'm running a 351C
bmc69
I'm running a Summit aluminum....and I moved the inlet and outlet ..
GrillMaster
GrillMaster
I dont have a tig welder and I suck at brazing so moving them is not an option. Wouldent mind if it fit into the stock mounts as well.
Deano
I got a griffin from summit and you can pick where you want the inlet and outlet. There about $200 and that's a plus!
wildbill
Old Bronco Guy
:D:D:D Just go to a radiator shop and have them swaped. works good did that when running a mustang 428 radiator in a bronco body and didnt cost very muck. good luck.;D;D;D Bill %):cool:;D
