Radius arm for axle wrap?
gjrock
Anacortes,WA
Can someone post some pics and how to connect the pivot end.I searched and found one pic.Sounds like this might be a cheap effective solution to tame the wrap monster.Need pics of the full set up.Thank you in advance.
bronko69er
EB Addict
Renton, WA
i think i have one brb....
nope i lied.
I was actually contemplating doing that but decieded to just use both and install coils in the rear. That will be my project this comming fall.
bronko69er
EB Addict
Renton, WA
you can pretty much mimic this setup except use a radius arm and wedges on the axle....
critt77matt
Kiln/Oxford, MS
Bronco driver issue #29 page 21 shows one on a full size 78-79. looks to be extended with a bushing on the end and attached to a crossmember
I did this back in '02. It was suppose to be temepary, proof of concept. still running today. Uses a pair of sway bar end links each angled at 45°. This spreads the lifting forces into each link. One link gets 50% of the force in a compression mode, the other gets 50% in a tension mode.
