Crude dude
- Feb 4, 2012
- 136
If you have bushings in hand, not on the axle, they will look like this <> from the side. The outside of the bushing <> isnt the same as the inside <> of the bushing. The caster is created by making parts of the bushing thicker and other parts thinner. This will turn the inner <> inside the outer <> (I know it sounds crazy but study them for a bit and you will see what Im saying. Now for example, if you are working on the Bronco with the front going to your left, the front of the <> inside the bushing will tip down for less caster and up for more caster. If either bushing is mislabeled then you have taken about an inch out of your lift or possibly added an inch but it really puts the front axle in a bind.
