661buster1963
- Feb 18, 2009
- 291
I thought I could figure this out, but could use some help. I am changing up the front lift on my 1968 Bronco a little. Today it has the second shock mount that was welded to the radius arm cap by PO, and the cast iron bracket that welds along the length of the coil spring tower. I think the PO said they were K BAR S purchases and a 2 1/2 inch lift with very stiff springs. I have some front shock hoops with double shock mounts to put on, they are 3 1/2" lift with progressive coils. I have some spare radius arms that have the shock mount bracket rivets already cut off and no welded bracket on the radius arm cap that i want to switch to to save a little work. i know the top sides of the radius arms are the ones with the threaded holes for the spring cup, same as the radius arm caps. What I dont know is how to tell which is left and right for both the arms and the caps, for that matter they may both be lefts
